Check if QuickTime is installed
// Returns 1 if quickTime is present and 0 if not
// It achieves this by trying to save a image as BMP which is only possible with quicktime installed
Function IsQuickTimeInstalled()
	variable err
	string errMsg
	// save current debugger state
	variable debuggerState, debugOnError, waveChecking
	DebuggerOptions
	debuggerState = V_enable
	debugOnError  = V_debugOnError
	waveChecking = V_NVAR_SVAR_WAVE_Checking
	// turn debugger off
	DebuggerOptions enable=0
	Make/FREE/N=(1,1) testImage
	NewPath/Q/O tempPath, SpecialDirPath("Temporary",0,0,0)
	err = GetRTError(0)
	ImageSave/P=tempPath/O testImage as "delete_me.bmp"
	errMsg = StringFromList(1,GetRTErrMessage())
	err = GetRTError(1)
	KillPath/Z tempPath
	// restore debugger state
	DebuggerOptions enable=debuggerState, debugOnError=debugOnError, NVAR_SVAR_WAVE_Checking=waveChecking
	if( err == 0 ) // quicktime found
		return 1
	else // err == 221 denotes that quicktime was not found, or other unknown error
Would a somewhat simpler method based on ImageFileInfo work?
Help Files wrote: ImageFileInfo [/P=pathName] fileNameStr
The ImageFileInfo operation supplies information about an image file without having to open the file and load the data into Igor.
ImageFileInfo works with the following file types: PICT, TIFF, GIF, JPEG, PNG, Targa, QuickTime, and BMP.
ImageFileInfo requires QuickTime. The operation will fail (V_flag=0) if you request information for a file format that is not supported by QuickTime.
I suppose it depends on whether V_flag=0 is returned only for unsupported file types (and not for other reasons). Otherwise you would have to depend on a specific RTE error code being detected. It is too inconvenient for me to uninstall QuickTime to test this, so I rely on others for comments.
Thanks for the pointer Stephen.
ImageFileInfo "throws" the same RTE if quicktime is not installed. So the whole GetRTError() and debugger state magic is the same. Additionally one has to have a known image file on disc for ImageFileInfo to work. And getting this to work both on Win and MacOSX would be equally ugly I guess.
