Getting the Average Value of Each Wave in a List of Waves
#pragma rtGlobals=1 // Use modern global access method. // Demonstration of getting the average values of a set of waves on a per-wave basis. // For a demo, execute: // DemoWaveAverages() // // The actual averaging is done in GetWaveAverages. This is the only function // you will need once you have come up with a wave containing a list of wave // references for the waves whose average values you want. // // The GetWaveAveragesFromTable function illustrates how to get such a // list wave from a table. // GetWaveAverages(listWave, outputName) // listWave contains a list of input waves. // outputName is the desired name for the output wave. // Returns a wave containing the average values of each waves. Function/WAVE GetWaveAverages(listWave, outputName) Wave /WAVE listWave // Contains list of numeric waves to be averaged String outputName // Desired name for output wave // Make the output wave Variable numWaves = numpnts(listWave) Make /O /D /N=(numWaves) $outputName Wave output = $outputName // Fill it with the averages Variable i = 0 for(i=0; i<numWaves; i+=1) Wave input = listWave[i] output[i] = mean(input) endfor return output // Return output wave to caller End // GetWaveAveragesFromTable(tableName, outputName) // tableName is the name of an existing table. // outputName is the desired name for the output wave. // Returns a wave containing the average values of each 1D, real, numeric wave in the table. Function/WAVE GetWaveAveragesFromTable(tableName, outputName) String tableName String outputName // Desired name for output wave if (WinType(tableName) != 2) Abort "Expected table name" endif String info = TableInfo(tableName, -2) Variable numColumns = NumberByKey("COLUMNS",info) // Number of columns in table numColumns -= 1 // Ignore the Point column // This is guaranteed to be big enough Make /FREE /WAVE /N=(numColumns) listWave // Get list of 1D real numeric waves in table Variable numWaves = 0 Variable index = 0 do Wave/Z w = WaveRefIndexed(tableName, index, 1) // Data columns only if (!WaveExists(w)) break // No more waves endif index += 1 if (WaveDims(w) > 1) // Ignore multi-dimensional waves continue endif if (WaveType(w) & 1) // Ignore complex waves continue endif if (WaveType(w,1) != 1) // Ignore text waves, wave waves and DFREF waves continue endif listWave[numWaves] = w // Add to list of waves whose averages we want numWaves += 1 while(1) // Get wave containing averages Wave averageWave = GetWaveAverages(listWave, outputName) // Since listWave is a free wave and there are no more references to it, // Igor will kill it automatically when the function ends. return averageWave End Function DemoWaveAverages() // Create sample data and table DoWindow /F DemoTable if (V_flag == 0) Edit /W=(5,44,809,254) /N=DemoTable Variable i for(i=0; i<5; i+=1) String name = "wave" + num2istr(i) Make/O/N=3 $name = i + p AppendToTable $name endfor else // We don't want to average the output wave RemoveFromTable averages endif // Get a list of waves whose averages we want Make /O /FREE /WAVE listWave = {wave0,wave1,wave2,wave3,wave4} // Get wave containing averages Wave averageWave = GetWaveAveragesFromTable("DemoTable", "averages") AppendToTable /W=DemoTable averageWave Print averageWave // Since listWave is a free wave and there are no more references to it, // Igor will kill it automatically when the function ends. End
