Get a Distinctive Color from a Set of Colors
hrodstein
// GetIndexedRGBColor(colorIndex, red, green, blue) // Given an index from 0 to 15, returns a color as r, g and b. // colorIndex is an input. red, green and blue are outputs. // Example: // Function Test() // Variable i // for(i=0; i<10; i+=1) // Variable red, green, blue // GetColor(i, red, green, blue) // Printf "%d: red=%d, green=%d, blue=%d\r", red, green, blue // endfor // End Function GetIndexedRGBColor(colorIndex, red, green, blue) Variable colorIndex Variable &red, &green, &blue // Outputs Variable numColors = 16 // Number of colors in the following switch colorIndex = mod(colorIndex, numColors) // Wrap around if necessary switch(colorIndex) case 0: // Time wave red = 0; green = 0; blue = 0; // Black break case 1: red = 65535; green = 16385; blue = 16385; // Red break case 2: red = 2; green = 39321; blue = 1; // Green break case 3: red = 0; green = 0; blue = 65535; // Blue break case 4: red = 39321; green = 1; blue = 31457; // Purple break case 5: red = 39321; green = 39321; blue = 39321; // Gray break case 6: red = 65535; green = 32768; blue = 32768; // Salmon break case 7: red = 0; green = 65535; blue = 0; // Lime break case 8: red = 16385; green = 65535; blue = 65535; // Turquoise break case 9: red = 65535; green = 32768; blue = 58981; // Light purple break case 10: red = 39321; green = 26208; blue = 1; // Brown break case 11: red = 52428; green = 34958; blue = 1; // Light brown break case 12: red = 65535; green = 32764; blue = 16385; // Orange break case 13: red = 1; green = 52428; blue = 26586; // Teal break case 14: red = 1; green = 3; blue = 39321; // Dark blue break case 15: red = 65535; green = 49151; blue = 55704; // Pink break endswitch End
