Load Space-Delimited Text File and Process Each Column
hrodstein
// This is an answer to the questions: // How do I load a space-delimited file? // How do I do a histogram of each loaded wave and create a graph showing the histogram? Menu "Load Waves" "Load Spaced Delimited File...", LoadSpaceDelimitedFile("", "") End Function ProcessWave(w) Wave w Variable numHistBins = 10 // Desired number of bins String destWaveName = NameOfWave(w) + "_hist" Make /O /N=(numHistBins) $destWaveName Histogram /B=1 w, $destWaveName Wave dest = $destWaveName Display dest End // LoadSpaceDelimitedFile(pathName, fileName) // Returns number of waves loaded or -1 if cancel. Function LoadSpaceDelimitedFile(pathName, fileName) String pathName // Name of an Igor symbolic path or "". String fileName // Name of file or full path to file. // First get a valid reference to a file. if ((strlen(pathName)==0) || (strlen(fileName)==0)) // Display dialog looking for file. Variable refNum Open/D/R/P=$pathName refNum as fileName fileName = S_fileName // S_fileName is set by Open/D if (strlen(fileName) == 0) // User cancelled? return -1 endif endif // Now load the data. The /V flag specifies space as delimiter. // Add the /A flag if you don't want the "Loading Delimited Text" dialog. // Add the /O flag if you want to overwrite existing waves with the same names. LoadWave /J /D /E=1 /K=0 /W /V={" ","",0,0} /P=$pathName fileName Variable numWavesLoaded = V_flag // V_flag is set by LoadWave if (numWavesLoaded == 0) return 0 endif String listOfWavesLoaded = S_waveNames // S_waveNames is set by LoadWave Variable i for(i=0; i<numWavesLoaded; i+=1) String name = StringFromList(i, listOfWavesLoaded) Wave w = $name // Create wave list ProcessWave(w) endfor return numWavesLoaded End
