Bonferroni correction
//********************************************************************* // statsBC // // Shawn Driscoll // Salk Institute for Biological Studies // // Implements Bonferroni correction. With a Family-wise error rate of // 0.05, the expected number of false positives will be 0.05. // // Parameters: // w - input wave of p-values // // Optional Parameters: // ncol - column number of p-values if input wave w is a 2D matrix //********************************************************************* function statsBC(w,[ncol]) //----------------------------------------------------------------- // parameters //----------------------------------------------------------------- wave w; variable ncol; //----------------------------------------------------------------- // variables //----------------------------------------------------------------- variable npnts,ndim; //----------------------------------------------------------------- // init variables //----------------------------------------------------------------- if(paramIsDefault(ncol)) ncol = 0; endif npnts = dimsize(w,0); ndim = dimsize(w,1); //----------------------------------------------------------------- // main function //----------------------------------------------------------------- if(ndim) w[][ncol] *= npnts; else w *= npnts; endif // set p-values greater than 1 to 1 w[] = w[p] > 1 ? 1 : w[p]; end
