Igor Spaces
Igor Spaces organises windows (Graphs, Tables, Layouts, Notebooks or Panels) in separate Spaces. When a Space is selected in the panel, only windows linked to it are shown.
How it works:
1. Launch Igor Spaces from "Windows/Packages" submenu.
2. Press the "New" button to create a new Space, name should be unique, otherwise you will be
 prompted to change your input. When a new "Space" is created it becomes your active working Space.
New Spaces are created below the active row selection, and at the moment you cannot change their order.
3.Press "Delete" to delete the selected space. Windows associated with the space are released and not
linked to any space ("" tag)
4. Press "All" to show/hide all windows whether linked to a Space or not.
5. When the Igor Spaces Panel is open any window you create is associated with the active Space.
6. Double click on a row to rename the Space
7. Press Shift + Click on a row of the ListBox to move the top window to the selected space
8. Press Alt + Click anywhere in the ListBox of the panel (rows or empty space below) to pin the top
window to all spaces (visible everywhere)
9. To unpin press Shift + Alt + Click anywhere in the ListBox to unpin the window (becomes free floating).
You can also make a normal window free-floating using the same procedure. Alternatively, if you want to
unpin and link it to a space goto 7.
10. Use Ctlr + click to mark/unmark a space with an asterisk and link it to the selected data folder in the data browser.
When selecting a Space with an asterisk the current data folder changes to the linked data folder.
Igor Space was developed and tested on Igor Pro 9.
Hope it will be useful to some of you.
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3				// Use modern global access method and strict wave access
#pragma DefaultTab={3,20,4}		// Set default tab width in Igor Pro 9 and later
#pragma IgorVersion = 9
#pragma ModuleName = ATH_Spaces
#pragma version = 1.2
// Copyright (c) 2022 Evangelos Golias.
// Contact: evangelos.golias@gmail.com
//	Permission is hereby granted, free of charge, to any person
//	obtaining a copy of this software and associated documentation
//	files (the "Software"), to deal in the Software without
//	restriction, including without limitation the rights to use,
//	copy, modify, merge, publish, distribute, sublicense, and/or sell
//	copies of the Software, and to permit persons to whom the
//	Software is furnished to do so, subject to the following
//	conditions:
//	The above copyright notice and this permission notice shall be
//	included in all copies or substantial portions of the Software.
//	THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
//	EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
//	OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
//	NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
//	HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
//	WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
//	FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
//	OTHER DEALINGS IN THE SOFTWARE.
// Igor Spaces organises windows (Graphs, Tables, Layouts, Notebooks or Panels) in separate
// Spaces. When a Space is selected in the panel, only windows linked to it are shown.
// Igor Spaces organises windows (Graphs, Tables, Layouts, Notebooks or Panels) in separate Spaces.
// When a Space is selected in the panel, only windows linked to it are shown.
// How it works:
// 1. Launch Igor Spaces from "Windows/Packages" submenu.
// 2. Press the "New" button to create a new Space, name should be unique, otherwise you will be
// prompted to change your input. When a new "Space" is created it becomes your active working Space.
// New Spaces are created below the active row selection, and at the moment you cannot change their order.
// 3.Press "Delete" to delete the selected space. Windows associated with the space are released and not
// linked to any space ("" tag)
// 4. Press "All" to show/hide all windows whether linked to a Space or not.
// 5. When the Igor Spaces Panel is open any window you create is associated with the active Space.
// 6. Double click on a row to rename the Space
// 7. Press Shift + Click on a row of the ListBox to move the top window to the selected space
// 8. Press Alt + Click anywhere in the ListBox of the panel (rows or empty space below) to pin the top
// window to all spaces (visible everywhere)
// 9. To unpin press Shift + Alt + Click anywhere in the ListBox to unpin the window (becomes free floating).
// You can also make a normal window free-floating using the same procedure. Alternatively, if you want to
// unpin and link it to a space goto 7.
// 10. Use Ctlr + click to mark/unmark a space with an asterisk and link it to the selected data folder in the data browser.
// When selecting a Space with an asterisk the current data folder changes to the linked data folder.
/// TL;DR:
/// SHIFT+Click: on a Space to associate with the top window.
/// Double-click: Rename the Space.
/// ALT+click (on an enpty row NOT a space): Pin top window to all Spaces.
/// SHIFT+ALT+click: unpin top window and make (now with no Space link, i.e. orphan).
/// CTRL+click (CMD+click on MacOS): link space to the selected data folder in Data Browser
/// (now marked with an asterisk). Current data folder changes when you select spaces with asterisk.
Menu "Macros"
	"Launch Spaces", /Q, ATH_Spaces#MenuLaunch()
static Function MenuLaunch()
	DFREF dfr = CreateDataFolderGetDFREF("root:Packages:ATH_DataFolder:Spaces")
	WAVE/Z/T/SDFR=dfr ATHSpacesTW
	NVAR/Z/SDFR=dfr gSelectedSpace
	NVAR/Z/SDFR=dfr gShowAllWindowsSwitch
	if(!WaveExists(ATHSpacesTW)) // If there is no text wave
		Make/T/N=1 dfr:ATHSpacesTW = "Main"
		Make/T/N=1 dfr:ATHSpacesTWDF
		variable/G dfr:gSelectedSpace = 0
		variable/G dfr:gShowAllWindowsSwitch = 0
		variable/G dfr:gShowOrphanWindowsSwitch = 0
	if(!(NVAR_Exists(gSelectedSpace) || NVAR_Exists(gShowAllWindowsSwitch)))
	if(WinType("ATH_SpacesPanel")) // Will return 7 for a panel, 0 if it's not there
		DoWindow/F ATH_SpacesPanel
		MakePanel()
static Function MakePanel()
	// Scale with IgorOptions here
	string igorInfoStr = StringByKey( "SCREEN1", IgorInfo(0)) // INFO: Change here if needed
	igorInfoStr = RemoveListItem(0, igorInfoStr, ",")
	variable screenLeft, screenTop, screenRight, screenBottom, panelLeft, panelTop, panelRight, panelBottom
	sscanf igorInfoStr, "RECT=%d,%d,%d,%d", screenLeft, screenTop, screenRight, screenBottom
	variable screenWidth, screenLength, listlength, listwidth
	screenWidth = abs(screenRight - screenLeft)
	screenLength = abs(screenBottom - screenTop)
	panelLeft = screenWidth * 0.875
	panelRight = screenWidth
	panelTop = screenLength * 0.2
	panelBottom = screenLength * 0.8
	listlength = abs(panelBottom - panelTop) * 0.925
	listwidth = abs(panelRight - panelLeft)
	variable pntConv = (CmpStr(IgorInfo(2), "Windows") == 0 && ScreenResolution >= 96) ? 1 : 72/ScreenResolution
	NewPanel /N=ATH_SpacesPanel/W=(panelLeft*pntConv, panelTop*pntConv, panelRight*pntConv, panelBottom*pntConv) as "ATH Spaces"
	SetDrawLayer UserBack
	Button NewSpaceB, pos={20,8.00},size={listwidth * 0.3333,20.00},help={"Create new space"},fColor=(3,52428,1)
	Button DeleteSpaceB, pos={20 + listwidth * 0.5,8.00},size={listwidth * 0.3333,20.00},title="Delete"
	Button DeleteSpaceB, help={"Delete existing space"},fColor=(65535,16385,16385)
	Button ShowAllB, pos={20,35},size={listwidth * 0.3333,20.00},title="All"
	Button ShowAllB, help={"Show all windows"},fColor=(32768,40777,65535)
	Button ShowOrphansB, help={"Show windows with no tag"}, title = "Orphans", fColor=(65535,65533,32768)
	Button ShowOrphansB, pos={20 + listwidth * 0.5,35},size={listwidth * 0.3333,20.00}
	ListBox listOfspaces, pos={1.00,60},size={listwidth,listlength},proc=ATH_Spaces#ListBoxFunction
	ListBox listOfspaces, fSize=14,frame=2,listWave=dfr:ATHSpacesTW,mode=2,selRow=gSelectedSpace
	// Add a help string
	string helpStr = "- SHIFT+Click: on a Space to associate with the top window.\n- Double-click: Rename the Space.\n- " +\
	"ALT+click (on an enpty row NOT a space): Pin top window to all Spaces.\n- SHIFT+ALT+click: unpin top window and make (now with no Space link, i.e. orphan).\n- "+\
	"CTRL+click(CMD+click): link space to the selected data folder in Data Browser (now marked with an asterisk).\nCurrent data folder changes when you select spaces with asterisk."
	TitleBox HelpTitle, title = "?", pos={20 + listwidth * 0.4,20}, frame=0, fSize=14,fstyle=1, fColor=(65535,0,0), labelBack=(65535,49151,55704), help={helpStr}
	ModifyControlList ControlNameList("ATH_SpacesPanel",";","*B") proc=ATH_Spaces#SpacesButton,win=ATH_SpacesPanel
Static Function SpacesButton(STRUCT WMButtonAction &s)
	if (s.eventCode != 2)
	WAVE/T/SDFR=dfr ATHSpacesTW, ATHSpacesTWDF
	variable index, showSwitchAll, showSwitchOrphans
	variable numSpaces = DimSize(ATHSpacesTW, 0)
	string msg
	NVAR/SDFR=dfr gSelectedSpace
	NVAR/SDFR=dfr gShowAllWindowsSwitch
	NVAR/SDFR=dfr gShowOrphanWindowsSwitch
	strswitch (s.ctrlName)
		case "NewSpaceB":
			string newSpaceNameStr = TrimString(GenericSingleStrPrompt("New space name (not empty or starting with *):", "Enter the name of the new Space"))
			if(!UniqueSpaceNameQ(ATHSpacesTW, newSpaceNameStr) || !strlen(TrimString(newSpaceNameStr)) || GrepString(newSpaceNameStr, "^\*")) // if the name is not unique or empty string
				do
					newSpaceNameStr = TrimString(GenericSingleStrPrompt("New space name (not empty or starting with *):", "Enter a *different* name for the new Space"))
				while(!UniqueSpaceNameQ(ATHSpacesTW, newSpaceNameStr) || !strlen(TrimString(newSpaceNameStr)) || GrepString(newSpaceNameStr, "^\*"))
			if (!numSpaces) // If you have deleted all spaces
				index = 0
				index = gSelectedSpace + 1
			InsertPoints index, 1, ATHSpacesTW
			InsertPoints index, 1, ATHSpacesTWDF
			ATHSpacesTW[index] = newSpaceNameStr
			// Set the space you created as active
			ListBox listOfspaces, selRow = index
			gSelectedSpace = index
			ShowWindowsOfSpaceTag(newSpaceNameStr, 1) // Show windows of the new Space - No windows to show!
			break
		case "DeleteSpaceB":
			if(numSpaces)
				if(gSelectedSpace > numSpaces - 1)
					gSelectedSpace = numSpaces - 1
				msg = "Do you want to delete \"" + SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace]) + "\""
				DoAlert/T="You are about to delete a Space", 1, msg
				if(V_flag == 1)
					ClearWindowsFromSpaceTag(SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace])) // has to come first!
					DeletePoints gSelectedSpace, 1, ATHSpacesTW
					DeletePoints gSelectedSpace, 1, ATHSpacesTWDF
					gSelectedSpace = gSelectedSpace == 0 ? 0: (gSelectedSpace - 1)
					ListBox listOfspaces, selRow = gSelectedSpace
			break
		case "ShowAllB":
			showSwitchAll = 1 - gShowAllWindowsSwitch
			ModifyControl ShowOrphansB, valueColor=(0,0,0), win=ATH_SpacesPanel
			if(showSwitchAll)
				gShowAllWindowsSwitch = 1
				ModifyControl ShowAllB, valueColor=(65535,0,0), win=ATH_SpacesPanel
				ShowAllWindows(0)
				ModifyControl ShowAllB, valueColor=(2,39321,1), win=ATH_SpacesPanel
				ShowAllWindows(1)
			break
		case "ShowOrphansB":
			showSwitchOrphans = 1 - gShowOrphanWindowsSwitch
			ModifyControl ShowAllB, valueColor=(0,0,0), win=ATH_SpacesPanel
			if(showSwitchOrphans)
				gShowOrphanWindowsSwitch = 1
				ModifyControl ShowOrphansB, valueColor=(65535,0,0), win=ATH_SpacesPanel
				ShowOrphanWindows(0)
				ModifyControl ShowOrphansB, valueColor=(2,39321,1), win=ATH_SpacesPanel
				ShowOrphanWindows(1)
			break
	endswitch
static Function ListBoxFunction(STRUCT WMListboxAction &LB_Struct)
	string msg, newSpaceNameStr, oldSpaceNameStr, winNameStr, buffer, prefix, listLinkedPP, linkedFolder
	variable hookresult = 0, i
	switch(LB_Struct.eventCode)
		// INFO: When you click outside of entry cells in the ListBox you get maxListEntries as row selection!
		case -1: // Control being killed
			//Do nothing
			break
		case 1: // Mouse down
			gSelectedSpace = LB_Struct.row
			// Press Option (Mac) or Alt (Windows) and click anywhere in the Listbox to
			// pin the top window (show in all spaces).
			if(LB_Struct.eventMod == 5)
				winNameStr = WinName(1, 87, 0) // Top Window: Graph, Table, Layout, Notebook or Panel
				SetWindow $winNameStr userdata(ATH_SpacesTag) = "ATH__PinnedWindow__ATH" // Assign special tag for pinned window
			// Press Shift+Option (Mac) or Shift+Alt (Windows) and click in the Listbox to
			// unpin the top window by setting an empty tag ""
			if(LB_Struct.eventMod == 7)
				SetWindow $winNameStr userdata(ATH_SpacesTag) = "" // Assign special tag for pinned window
			hookresult = 1
			break
		case 2: // Mouse up
			if(GrepString(ATHSpacesTW[gSelectedSpace], "^\*") && strlen(ATHSpacesTWDF[gSelectedSpace]))
				SetDataFolder ATHSpacesTWDF[gSelectedSpace]
			hookresult = 1
			break
		case 3: // Double click
			if (gSelectedSpace > numSpaces - 1)
				hookresult = 1
				break
			msg = "Rename Space \"" + SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace]) + "\""
			oldSpaceNameStr = ATHSpacesTW[gSelectedSpace] // Do not sanitise now
			if(GrepString(oldSpaceNameStr, "^\*"))
				prefix = "*"
				prefix = ""
			oldSpaceNameStr = SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace])
			newSpaceNameStr = oldSpaceNameStr // start with the old string, help with correcting typos
			Prompt newSpaceNameStr, "New name"
			DoPrompt "Change name of Space", newSpaceNameStr
			if(V_flag)
				return 1
			newSpaceNameStr = TrimString(newSpaceNameStr)
			if(!UniqueSpaceNameQ(ATHSpacesTW, newSpaceNameStr) || !strlen(TrimString(newSpaceNameStr))|| GrepString(newSpaceNameStr, "^\*")) // if the name is not unique or empty string
				do
					newSpaceNameStr = TrimString(GenericSingleStrPrompt("Space name already exists or string is empty or starts with *, enter a valid name:", \
																			"Enter a *unique* name for the new Space"))
				while(!UniqueSpaceNameQ(ATHSpacesTW, newSpaceNameStr) || !strlen(TrimString(newSpaceNameStr))|| GrepString(newSpaceNameStr, "^\*"))
			ATHSpacesTW[gSelectedSpace] = prefix + newSpaceNameStr
			RenameSpaceTagOnWindows(oldSpaceNameStr, newSpaceNameStr) // newSpaceNameStr has no * prefix!
			hookresult = 1
			break
		case 4: // Cell selection (mouse or arrow keys)
			if(LB_Struct.eventMod == 9) // If CTRL+click or CMD+click (Mac) is pressed in a row
				if(GrepString(ATHSpacesTW[gSelectedSpace], "^\*"))
					buffer = ATHSpacesTW[gSelectedSpace]
					ATHSpacesTW[gSelectedSpace] = buffer[1, inf]
					ATHSpacesTWDF[gSelectedSpace] = ""
					linkedFolder = GetBrowserSelection(0);variable errorCode = GetRTError(1)
					if(errorCode)
						print "athinaSpacesError: " + GetErrMessage(errorCode, 3)
						buffer = "*" + ATHSpacesTW[gSelectedSpace]
						if(exists(linkedFolder)==1)
							ATHSpacesTWDF[gSelectedSpace] = GetWavesDataFolder($linkedFolder,1)
						elseif(exists(linkedFolder)==2)
							ATHSpacesTWDF[gSelectedSpace] = ParseFilePath(1, linkedFolder, ":", 1, 0)
						elseif(DataFolderExists(linkedFolder))
							ATHSpacesTWDF[gSelectedSpace] = linkedFolder
						else // Remove asterisk, did not catch a directory
				ShowWindowsOfSpaceTag(SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace]), 1)
			DoWindow/F $LB_Struct.win // Bring panel to the FG
			hookresult = 1
			break
		case 5: // Cell selection plus Shift key (Assign window to Space)
			// WinName(0, 87) is the "ATH Spaces" panel
				hookresult = 1
				break
			SetWindow $winNameStr userdata(ATH_SpacesTag) = SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace]) // Assign tag to window
			// Do we have a linked panel?
			// List of known linked profile extensions (SumBeamsProfile, LineProfile, PlaneProfileZ)
			listLinkedPP = "ImageSource;ImageZPP;ImageLPP;ImagePPZ;iXPSPP"
			for(i = 0; i < 5; i++) // Manually add here maxVal as ItemsInList(listLinkedPP)
				buffer = GetUserData(winNameStr, "", "ATH_LinkedWin" + StringFromList(i, listLinkedPP))
				if(strlen(buffer))
					SetWindow $buffer userdata(ATH_SpacesTag) = SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace]) // Assign tag to window
			hookresult = 1
			break
	endswitch
	return hookresult
static Function ShowWindowsOfSpaceTag(string spaceTagStr, variable showSwitch)
	// showSwitch = 0 (hide window)
	// showSwitch = 1 (show window)
	string winNameStr, getSpacetagStr
	string allWindowsStr = SortList(RemoveFromList("ATH_SpacesPanel",WinList("*",";","WIN:87")), ";", 16)
	variable i, imax = ItemsInList(allWindowsStr)
	for(i = 0; i < imax; i++)
		winNameStr = StringFromList(i, allWindowsStr)
		getSpacetagStr = GetUserData(winNameStr, "", "ATH_SpacesTag")
		if(!cmpstr(getSpacetagStr, spacetagStr, 0)) // comparison is case-insensitive.
			SetWindow $winNameStr hide = 1 - showSwitch // Match
		elseif(!cmpstr(getSpacetagStr, "ATH__PinnedWindow__ATH", 0)) // Pinned window
			SetWindow $winNameStr hide = 0 // Always show
			SetWindow $winNameStr hide = showSwitch
static Function RenameSpaceTagOnWindows(string oldspaceTagStr, string newspaceTagStr)
	string winNameStr = "", getSpacetagStr
	variable i = 0
	do
		i++
		winNameStr = WinName(i, 87, 0) // i = 0 is the ATH_SpacesPanel, so we skip checking it
		if(!cmpstr(getSpacetagStr, oldspaceTagStr, 0)) // comparison is case-insensitive.
			SetWindow $winNameStr userdata(ATH_SpacesTag) = newspaceTagStr
	while(strlen(winNameStr))
static Function ClearWindowsFromSpaceTag(string spaceTagStr)
	variable i = 0
	do
		i++
		// Catch "" from setting SetWindow $"" hide = 1/0
		if(!strlen(winNameStr))
			break
static Function UniqueSpaceNameQ(WAVE/T textW, string spaceNameStr)
	/// Return true of spaceNameStr in not an element of textW (case-insensitive), i.e it is Unique
	variable numEntries = DimSize(textW, 0), i
	for(i = 0; i < numEntries; i++)
		if(!cmpstr(SanitiseATHSpaceName(textW[i]), spaceNameStr))
	return 1
static Function/S SanitiseATHSpaceName(string spaceNameStr)
	if(GrepString(spaceNameStr, "^\*"))
		return spaceNameStr[1,inf]
		return spaceNameStr
static Function ShowAllWindows(variable showSwitch)
	string winNameStr
	variable i = 0
	do
		i++
			break
		if(!cmpstr(winNameStr, "ATH_SpacesPanel", 0))
			continue
static Function ShowOrphanWindows(variable showSwitch)
	// Show windows with no tag
	variable i = 0
	do
		i++
			break
		if(!strlen(getSpacetagStr))
static Function/DF CreateDataFolderGetDFREF(string fullpath, [int setDF]) // Cornerstone function
	/// Create a data folder using fullpath and return a DF reference.
	/// If parent directories do not exist they are created.
	/// SetDF set the cwd to fullpath if set.
	/// N.B If the folder contains paths with liberal names without
	/// enclosing single quotes then the path is sanitised
	setDF = ParamIsDefault(setDF) ? 0 : setDF
	// Sanitize path, liberal names
	// It is not always needed,
	if(!isPathStringLegalQ(fullpath))
		fullpath = SanitizePath(fullpath)
	// If the directory exists
	if(DataFolderExists(ParseFilePath(2, fullpath, ":", 0, 0))) // ":" at the end needed to function properly
		DFREF dfr = $fullpath
		if (setDF)
			SetDataFolder dfr
		return dfr
	/// Create a list of missing paths, parents first.
	variable steps = ItemsInlist(ParseFilePath(2, fullpath, ":", 0, 0), ":"), i
	string fldrs = "", fldrstr
	for(i = 1; i < steps ; i++) // i = 0 & steps return NULL string
		fldrs += ParseFilePath(1, fullpath, ":", 0, i) + ";"
	fldrs += ParseFilePath(2, fullpath, ":", 0, 0) // add the full path (last child folder is created here
	// now create the folder from parent to child
	variable fldrnum = ItemsInList(fldrs)
	for(i = 0; i < fldrnum; i++)
		fldrstr = StringFromList(i, fldrs)
		if(!DataFolderExists(fldrstr)) // ":" at the end needed to function properly - No! (08.01.23)
			NewDataFolder/O $RemoveEnding(fldrstr, ":") // Here the last ":" pops an error
	if (setDF)
		SetDataFolder dfr
	return dfr
static Function/S GenericSingleStrPrompt(string strPrompt, string msgDialog)
	string returnStrVar
	Prompt returnStrVar, strPrompt
	DoPrompt msgDialog, returnStrVar
	if(V_flag)
		Abort
	return returnStrVar
static Function isPathStringLegalQ(string path)
	variable steps = ItemsInlist(path, ":"), i
	string str
	for(i = 0; i < steps ; i++)
		str = StringFromList(i, path, ":")
		if(isLiberalQ(str) && (cmpstr(str[0],"'") || cmpstr(str[strlen(str)-1],"'")) )
	return 1
static Function/S SanitizePath(string path)
	// Fix liberal relative pathnames in fullpath
	string spath = "", str
	for(i = 0; i < steps ; i++) // i = 0 & steps return NULL string
		if(isLiberalQ(str))
			spath += PossiblyQuoteName(str) + ":"
			spath += str + ":"
	return spath
static Function isLiberalQ(string s)
	// Checks if a string is liberal.
	// Returns 0 for empty string
	string regex = "^[a-zA-Z]{1}[a-zA-Z0-9_]+$"
	if(GrepString(s, regex) || !strlen(s))
		return 1
// AfterWindowCreatedHook - Used in Spaces to assign tags to new windows
Function AfterWindowCreatedHook(string windowNameStr, variable winTypevar)
	// Every window created is assigned to the active Space if the panel is there
		DFREF dfr = ATH_DFR#CreateDataFolderGetDFREF("root:Packages:ATH_DataFolder:Spaces")
		windowNameStr = WinName(0, 87, 1) // Window is created, visible only
		if(DimSize(ATHSpacesTW,0) && cmpstr(windowNameStr,"ATH_SpacesPanel")) // We have to have at least one space
			//Sanitize names
				SetWindow $windowNameStr userdata(ATH_SpacesTag) = ATH_Spaces#SanitiseATHSpaceName(ATHSpacesTW[gSelectedSpace])
				SetWindow $windowNameStr userdata(ATH_SpacesTag) = ATHSpacesTW[gSelectedSpace]
	return 0 // Ignored
IgorSpaces_7.ipf (23.18 KB)
Nice idea! Thank you. Just a few comments.
* Distribution and management of the code could be easier all around if you would post it as an Igor project. See the button Create A Project at the top left of the page for Projects List. Also consider making the procedure file and the project itself compatible with the Igor Exchange Project Updater package.
* The menu might be better put in the Windows sub-menu rather than in Macros.
* Are you aware of the Windows Desktop project that has a similar purpose to what you are attempting in your code?
In reply to by jjweimer
Hi jjweimer,
* I will post it as a new project soon and make it compatible with the Updater.
* You are right, it's better under the "Windows", maybe "Windows/Packages".
* I have see and tested Adam's package. We are going to use the package during beamtimes so it's helpful to have named spaces (e.g. "Sample #3245 XPS after 500°C annealing"). When you have more than 4-5 Desktops/Spaces you forget where is what. That's was the only downside of Adam's package. I coded IgorSpaces in a day, if I wanted to customise ACL_WindowDesktops it would have taken me much more time!
Thanks for your comments.
