Multipeak Fit: Fit your experimental data with ... your experimental data?!
Igor's Multipeak Fit is convenient to fit analytical peak functions to data. But there might be times when you want to include some other data (wave) into your fit. For example, to find a match between different measurements or to include reference data into the fit. This code snippet provides the framework to fit experimental data including Gaussian broadening with Multipeak Fit (MPF).
The data is prepared in numbered folders (such as 'root:myData_1:') with numbered wave names (such as 'myPeak0', 'myPeak1' ...). Since MPF can only interact via numerical values, these numbers are later used to select the folder and desired data. After loading MPF, first navigate to Analysis => Multipeak Fit => Prepare Data Peak Function. A small prompt appears where the base folder and wave names are set ("root:myData_" and "myPeak" in above example).
Then start a fit set. Now, the DataPeak fit function is available from within MPF. Here, the last two parameters control the folder and wave number of the data you have just set up. These two parameters need to be on Hold at all times, or the fit will fail. Dial in the desired value to select the data to fit (e.g., folder 1 and wave 2), then run the fit. The first three parameters control the relative x-shift, Gaussian broadening and height (scale) of the data. If you want to switch off broadening, just set and hold this parameter at zero.
You can provide data in two variants: as-is or normalized. If you provide data as-is, then the first parameter can be seen as a 'relative shift' and the third parameter is a 'relative scale'. But you might want to normalize the data before using it in the fit: This would mean to normalize the data height to a maximum of 1 and/or adjust the x-scaling to be centered at zero (so that the 'peak' in your data is placed at x=0). For normalized data, the first parameter can be seen as a 'peak position' and the third parameter is 'height'.
Some notes and caveats:
- You might want to at least remove the baseline from your input data or this baseline will appear in (and be scaled by) the fit.
- If the data's x-range is smaller than needed for the fit, endpoints will be repeated to extend the range.
- The output Location, Amplitude, Area, and FWHM values are numerically determined and may be junk depending on how much your data resembles 'a peak'.
#pragma TextEncoding = "UTF-8" #pragma rtGlobals = 3 #pragma IgorVersion = 8.00 #pragma moduleName = MPFDataFit #pragma DefaultTab = {3,20,4} static StrConstant kMPF_WorkingDir = "root:Packages:MultiPeakFit2:" Menu "Analysis" Submenu MPFDataFit#CreateDataFitMenu() // add menu entry after loading MPF "Prepare Data Peak Function", /Q, MPF_PrepareDataFit() End End static Function/S CreateDataFitMenu() return SelectString(DataFolderExists(kMPF_WorkingDir),"-","Multipeak Fit") End // +++++++++ Function MPF_PrepareDataFit() // setup for data locations String setBaseFolder = "", setBaseName = "" SVAR/Z baseFolder = $(kMPF_WorkingDir+"MPF_DataFit_baseFolder") // load previous settings SVAR/Z baseName = $(kMPF_WorkingDir+"MPF_DataFit_baseName") if (SVAR_Exists(baseFolder)) setBaseFolder = baseFolder endif if (SVAR_Exists(baseName)) setBaseName = baseName endif Prompt setBaseFolder,"Set base folder name without trailing number (e.g., \"root:myFit_\"):" Prompt setBaseName,"Set base data name without trailing number (e.g., \"peak_\"):" DoPrompt "Setup MPF data fit", setBaseFolder, setBaseName if (V_Flag) return -1 endif if (!strlen(setBaseFolder) || !strlen(setBaseName)) Abort "You need to enter both a folder path and base data name." endif int i, j, sourceFound = 0 if (!DataFolderExists(kMPF_WorkingDir)) // if MPF was not started yet => create basic folder structure DFREF saveDF = GetDataFolderDFR() SetDataFolder root: for (i = 1; i < ItemsInList(kMPF_WorkingDir,":"); i++) NewDataFolder/O/S $StringFromList(i,kMPF_WorkingDir,":") endfor Variable/G currentSetNumber = 0 SetDataFolder saveDF endif setBaseFolder = RemoveEnding(setBaseFolder , ":") // make sure no colon was entered String/G $(kMPF_WorkingDir+"MPF_DataFit_baseFolder") = setBaseFolder String/G $(kMPF_WorkingDir+"MPF_DataFit_baseName") = setBaseName for (i = 0; i < 10 && !sourceFound; i++) // try to look for the data in the first 10 folder / waves for (j = 0; j < 10 && !sourceFound; j++) Wave/Z source = $(setBaseFolder+num2str(i)+":"+setBaseName+num2str(j)) sourceFound = WaveExists(source) endfor endfor if (!sourceFound) // still nothing found? => have a simple check to remind the user DoAlert/T="Checking folder and data" 0, "Your first folder and/or data does not seem to exist yet. Make sure to prepare the data in the format: "+setBaseFolder+"[NUM]:"+setBaseName+"[NUM]" endif return 0 End //######## static Function/Wave getSource(Wave cw) // get source data from saved base names SVAR/Z baseFolder = $(kMPF_WorkingDir+"MPF_DataFit_baseFolder") SVAR/Z baseName = $(kMPF_WorkingDir+"MPF_DataFit_baseName") if (SVAR_Exists(baseFolder) && SVAR_Exists(baseName)) Wave/Z source = $(baseFolder+num2str(cw[3])+":"+baseName+num2str(cw[4])) if (WaveExists(source) && WaveType(source,1) == 1 && WaveDims(source) == 1) return source endif endif return $"" End //######## static Function MPF_setHoldStateForPeak(Wave cw, String holdStr) // injects hold state for the current peak DFREF DFpath = GetWavesDataFolderDFR(cw) int peakNum sscanf NameOfWave(cw), "Peak %d Coefs", peakNum if (!DataFolderRefStatus(DFpath) || numType(peakNum) != 0 || peakNum < 0) return -1 endif SVAR gName = DFPath:GraphName String pName = gName+"#MultiPeak2Panel" // the MPF panel if (WinType(pName) == 7) Wave/T HoldStrings = DFPath:HoldStrings Execute/Z "WMMultiPeakFit#MPF2_RefreshHoldStrings(\""+pName+"\")" // first, grab the latest hold settings from the panel HoldStrings[peakNum+1] = holdStr // inject hold string Execute/Z "WMMultiPeakFit#SetHoldCheckboxesFromWave(WMMultiPeakFit#GetSetNumberFromWinName(\""+pName+"\"))" // rewrite to panel endif return 0 End //####### MPF peak format functions ##### Function/S DataPeak_PeakFuncInfo(Variable which) // pass names to MPF Switch (which) case 0: return "LocShift;Broaden;Height;Folder;DataNo;" case 1: return "MPF_DataPeakFunc" case 2: return "MPF_GaussToDataPeakGuess" case 3: return "MPF_DataPeakParams" case 4: return "Location;Height;Area;FWHM;" EndSwitch End //+++++++ Function MPF_GaussToDataPeakGuess(Wave cw) // initializes parameters, and set hold state // cw values are: "PosShift;GaussWidth;Height;Folder;DataNo;" Redimension/N=5 cw int i,j, sourceFound = 0 for (i = 0; i < 10 && !sourceFound; i++) for (j = 0; j < 10 && !sourceFound; j++) cw[3] = i cw[4] = j Wave/Z source = getSource(cw) // grabs the first valid source wave sourceFound = WaveExists(source) endfor endfor int normInt = 1, normPos = 1 if (sourceFound) Variable wMax = WaveMax(source) Variable left = leftx(source) < rightx(source) ? leftx(source) : rightx(source) Variable right = leftx(source) < rightx(source) ? rightx(source) : leftx(source) normInt = wMax > 0.9 && wMax < 1.1 ? 0 : 1 normPos = left < 0 && right > 0 ? 0 : 1 endif cw[0] = normPos ? 0 : cw[0] // if data seems centered around zero, peak position can stay cw[1] = 0.5 // initial Gaussian broadening cw[2] = normInt ? 1 : cw[2] // if data is normalized, peak height can stay // this needs to be executed later or the hold state will be reset Execute/P/Q "MPFDataFit#MPF_setHoldStateForPeak("+GetWavesDataFolder(cw,2)+", \"00011\")" return 0 End //+++++++ Function MPF_DataPeakFunc(Wave cw, Wave yw, Wave xw) : FitFunc // the fit function Wave/Z source = getSource(cw) if (!WaveExists(source)) yw = NaN if (Exists("MPF2_DisplayStatusMessage")) // display an error in the MPF graph Execute/Z "MPF2_DisplayStatusMessage(\"Base folder setup wrong or data not found.\","+GetWavesDataFolder(cw,1)+")" endif return -1 endif Duplicate/free source, yWave SetScale/P x, DimOffset(source,0)+cw[0], DimDelta(source,0), ywave // prepare shifted convolution wave PeakConvolveGaussHelper(yWave, cw[1]) // Gauss convolution Variable minX = pnt2x(yWave,0), maxX = pnt2x(yWave,numpnts(yWave)-1) // make sure to not run out-of-bounds (end-point data is repeated) yw = xw[p] >= minX ? ( xw[p] <= maxX ? cw[2]*yWave(xw[p]) : cw[2]*yWave(maxX) ) : cw[2]*yWave(minX) return 0 End //+++++++ Function MPF_DataPeakParams(Wave cw, Wave sw, Wave outWave) Variable Amplitude = NaN, Location = NaN, FWHM = NaN, PeakArea = NaN // set to NaN for now FindPeakStatsHelper(cw, Amplitude, Location, FWHM, PeakArea) // approximately calculates all results // cw values are: "PosShift;GaussWidth;Height;Folder;DataNo;" // output values are: "Location;Height;Area;FWHM;" outWave[0][0] = Location // position outWave[0][1] = NaN outWave[1][0] = Amplitude // height outWave[1][1] = NaN outWave[2][0] = PeakArea // area outWave[2][1] = NaN outWave[3][0] = FWHM // FWHM outWave[3][1] = NaN return 0 End //####### Static Function PeakConvolveGaussHelper(Wave in, Variable width) // convolve with a prepared Gaussian if (width == 0 || numtype(width) != 0) return 0 endif Variable pnt, dx = DimDelta(in,0), size = DimSize(in,0) width = abs(width/dx)/sqrt(2) // width normalized by x scaling and convert to expected Gauss 'width' pnt = round(max(abs(10*width),11)) // create a wave 10 times the Gauss width (5 sigma on each side) pnt = min(pnt, 2*numpnts(in)+1) // doesn't have to be larger than two times the full input data pnt = pnt+!mod(pnt, 2) // force odd size Make/FREE/D/N=(pnt) GaussWave GaussWave = Gauss(x, (pnt-1)/2, width) Variable A = sum(GaussWave) // make sure the Gauss area limited even for a few points if (A > 1) GaussWave /= A endif Make/FREE/D/N=(2*pnt+size) temp = in[0] // enlarge the wave to get the full convolution range temp[pnt,size+pnt-1] = in[p-pnt] temp[size+pnt,size+2*pnt-1] = in[size-1] MatrixOP/Free temp = replaceNaNs(temp,0) // makes sure there are no NaN values in-between Convolve/A GaussWave temp in[0,size-1] = temp[p+pnt] End //######### // recalculate the (almost) full peak and extract all result values numerically Static Function FindPeakStatsHelper(Wave cw, Variable &Amplitude, Variable &Location, Variable &FWHM, Variable &PeakArea) Wave/Z sw = getSource(cw) if (!WaveExists(sw)) return -1 endif // cw values are: "PosShift;GaussWidth;Height;Folder;DataNo;" Variable left = pnt2x(sw,0)+cw[0], right = pnt2x(sw,numpnts(sw)-1)+cw[0] Variable pntSize = DimSize(sw,0)*10 // create a big wave (fine increments) pntSize = pntSize > 100000 ? 100000 : pntSize // make sure its not too big Make/FREE/D/N=(pntSize+1) yw, xw Make/FREE/D/N=2 Levels SetScale/I x, left, right, xw; xw = x //+++++ find values +++++ MPF_DataPeakFunc(cw, yw, xw) // recalculate the peak with the coef set PeakArea = AreaXY(xw, yw, left, right) // the area is calculated for the full source range WaveStats/Q yw Amplitude = cw[2] > 0 ? V_max : V_min Location = cw[2] > 0 ? xw[V_maxloc] : xw[V_minloc] FindLevels/Q/D=Levels yw, Amplitude/2 // find the half-maximum positions if (V_LevelsFound == 2) left = xw[Levels[0]] right = xw[Levels[1]] FWHM = abs(left - right) endif if (numtype(FWHM) != 0) return 0 endif //++++++ recalculate with higher resolution ++++++ // choose a range just a bit bigger than the FWHM SetScale/I x, left - 2*FWHM/(pntsize+1), right + 2*FWHM/(pntsize+1), xw; xw = x MPF_DataPeakFunc(cw, yw, xw) WaveStats/Q yw Amplitude = cw[2] > 0 ? V_max : V_min Location = cw[2] > 0 ? xw[V_maxloc] : xw[V_minloc] FindLevels/Q/D=Levels yw, Amplitude/2 if (V_LevelsFound == 2) left = xw[Levels[0]] right = xw[Levels[1]] FWHM = abs(left - right) endif return 0 End
