Generate checksums for files
cpr
This simple (Windows) function uses the certutil function built into Windows for computing the hash of a file from a choice of algorithms.
A file containing the computed hash is generated, the hash is returned, and printed to history - whichever you like.
Function can be called from inside another function, command line, or executed interactively.
In line e.g. String hash = getHash("C:\path\some.file","MD5",quiet=1)
From the command line e.g.: getHash("C:\path\some.file","MD5")
// menu Menu "Tools" "Generate checksum",/Q, getHashManually() end // List of built-in Windows hash functions provided by CertUtil Static StrConstant hashFuncLst="MD2;MD4;MD5;SHA1;SHA256;SHA384;SHA512;" //___________________________________________________________________________________________________ // Function to get the hash of an input file (objectStr) output as a text file (eg .md5), a string variable, and printed to history // Valid values for hashFunc: MD2 MD4 MD5 SHA1 SHA256 SHA384 SHA512 // Synax - cmd.exe /C certutil -hashfile C:\\file.txt MD5 Function/S getHash(String ObjectStr,String hashFunc[,Variable quiet]) String fileHash="", LineStr="", PathStr, fexts Variable fileID,i // make the file extension (lowercase) fexts=LowerStr(hashFunc)[0,2] // make sure the path is in windows form ObjectStr=ParseFilePath(5, ObjectStr, "\\", 0, 0) // make a new path in the location of the file to be hashed PathStr = ParseFilePath(1, ObjectStr, "\\", 1, 0) NewPath /O/Q/Z ObjectPath, PathStr // execut cmd script ExecuteScriptText/B/Z "cmd.exe /C certutil -hashfile \""+ObjectStr+"\" "+hashFunc // read the output from the getHash command do LineStr = StringFromList(i,S_value, "\n") // Success if (Stringmatch(lineStr, hashFunc+" hash of "+ ObjectStr +":\r")) fileHash = StringFromList(i+1,S_value, "\n") // make a new hash file without the other CMD lines in it open /P=ObjectPath fileID as ParseFilePath(3, ObjectStr, "\\", 0, 0)+"."+fexts fprintf fileID, replaceString("\r",StringFromList(i+1,S_value, "\n"),"") close fileID // print output if (paramisDefault(quiet)) Print hashFunc+" hash of "+ParseFilePath(0, ObjectStr, "\\", 1, 0)+": "+fileHash endif Break // Handle other errors else if (paramisDefault(quiet)) Print "There was a problem generating a "+hashFunc+" hash for "+ParseFilePath(0, ObjectStr, "\\", 1, 0) endif break endif i+=1 while (i < ItemsInList(S_value, "\n")) return fileHash end //___________________________________________________________________________________________________ // Function to allow manual generation of checksum Function getHashManually() Open/D/R/MULT=1/F="*"/M="Select files for generating a checksum" fileID if(strlen(S_fileName)==0) return 0 // user didn't choose a file else S_filename=replacestring("\r",S_filename,";") endif String hashFunc Prompt hashFunc "Choose a checksum method", popup hashFuncLst DoPrompt/HELP="" "Checksum generator" hashFunc If (V_flag!=0) return 0 // user hit cancel endif Variable i for (i=0;i<itemsinlist(S_filename);i+=1) gethash(stringfromlist(i,S_filename),hashFunc) endfor end //___________________________________________________________________________________________________
For what it's worth, Igor has functions that can be used to calculate many of these hashes. The hash() function is for strings, and the WaveHash() function for waves. These have the disadvantage that you'd need to read the file's data into Igor (probably as a string using FBinRead) but the advantage of being cross platform and not needing to rely on ExecuteScriptText.
November 9, 2020 at 07:42 am - Permalink
Here is a platform independent version :
May 28, 2021 at 08:21 am - Permalink
