A forced NewDataFolder to handle complex paths
pokeeffe
// forceNewDataFolder( destPath ) // string destPath relative or absolute path of directory to create // // Returns a DFREF which can be used to switching or referring to // Function/DF forceNewDataFolder( destPath ) string destPath variable i string folder = "" string up = "" DFREF sav0 = GetDataFolderDFR() DFREF out for (i=0; i<ItemsInList(destPath, ":"); i+=1) // for each folder in path // folder = PossiblyQuoteName(StringFromList(i, destPath, ":")) // extract from list, possibly quoting folder = ReplaceString("'", StringFromList(i, destPath, ":"), "") // extract from list, quotes will screw up NewDatafolder If ( !strlen(folder) ) // if blank entry up += SelectString(i, "", ":") // include semicolon, except for first row continue // skip remainder of loop elseif (strlen(up)) // if not blank but was up += ":" // grouped :'s lose the first ":" so replace it up = up[0, min(strlen(up), ItemsInList(GetDataFolder(1), ":"))-1] // remove :'s which refer upwards of root SetDataFolder $up // switch up levels endif If (cmpstr(folder,"root")) // if folder isn't "root" NewDataFolder/O/S $folder // create/switch to else // but if it is SetDataFolder root: // start in root, don't try to make it endif up = "" // clear up before next loop endfor out = GetDataFolderDFR() // capture current location to DFREF first SetDataFolder sav0 // then return user to prev folder return out // and hand back the DFREF end
