Synchronized Windows
harneit
Igor supports exterior panels that stick to the target window, but only for graphs and panels.
To use, create two windows and install the link between them using SyncWinInstall().
The following examples are also given in the procedure file.
Example 1:
Example 2:
Example 3:
SyncWin
extends this idea to any pair of target windows (also tables, layouts, notebooks).To use, create two windows and install the link between them using SyncWinInstall().
Example 1:
string myGraph = "MyOtherGraph" Display /N=$myGraph /W=(300,90,500,190) Display /N=MyFirstGraph /W=(350,100,550,200) SyncWinInstall(myGraph)
Example 2:
string myPanel = "Panel0", myTable = "Table0" Edit /N=$myTable /W=(100,50,300,150) NewPanel /N=$myPanel /W=(150,60,350,160) SyncWinInstall(myPanel, mainWin = myTable, anchor = "LB", killmode = 1)
Example 3:
string myLayout = "Layout0", myNB = "NB0" NewLayout /N=$myLayout /W=(200,70,400,170) NewNotebook /F=1 /N=$myNB /W=(250,80,450,180) SyncWinInstall(myNB, mainWin = myLayout, anchor = "TC", killmode = 2)
Synchronized Windows IGOR.6.20.x
Release File: | SyncWin.ipf (7.19 KB) |
Version: | IGOR.6.20.x |
Version Date: | |
Release Notes: | tested on ip6.2/win |
