Generic Window Hook
harneit
GenericWindowHook.ipf provides
1) a generic window hook function that monitors events, GenericWinHook(), and
2) an installer function, InstallGenericWinHook(), that sets up an exterior panel (dubbed here the "event panel") to show all monitored events.
- Works for any window that can receive events (Graphs, Tables, Layouts, Panels, Notebooks).
- You can simply use the event panel to examine what really happens to your window while developing your own hook function.
- You can also use the GenericWinHook() code as a starting point for own your hook function.
Usage:
- From the command line or from your own function, call
- You can also provide a target window name (here:
- After that, watch what kind of events your target window is receiving in response to user actions (mouse, keyboard, menu, ...)
Full documentation is in the procedure file.
Usage:
for the top window (Graph, Panel, Table, Layout, or Notebook).- You can also provide a target window name (here:
Table0
) using the optional parameter syntax: InstallGenericWinHook(winName = "Table0")
.- After that, watch what kind of events your target window is receiving in response to user actions (mouse, keyboard, menu, ...)
Generic Window Hook IGOR.6.20.x-1.0
Release File: | GenericWindowHook.ipf (7.04 KB) |
Version: | IGOR.6.20.x-1.0 |
Version Date: | |
Version Major: | 1 |
Version Patch Level: | 0 |
Release Notes: | First release. Documentation is in the procedure file. |
