[XOP] C++ Wrapper for MDAccessNumericWaveData
thomas_braun
Examples:
<br /> // waveH points to a double/NT_FP64 wave<br /> double *dbl = getWaveDataPtr<double>(waveH)<br /> // float/NT_FP32<br /> float *flt = getWaveDataPtr<float>(waveH)<br /> // int/NT_I32<br /> int *integer = getWaveDataPtr<int>(waveH)<br />
In case you pass a textwave or the wave layout has changed at some point in the future the return value is null.
Be sure to place the template function into a header file.
<br /> // check the return value for NULL<br /> template <class T> T* getWaveDataPtr(waveHndl waveH){<br /> int accessMode = kMDWaveAccessMode0;<br /> int ret=-1;<br /> BCInt dataOffset;<br /> T *dataPtr;<br /> <br /> ret = MDAccessNumericWaveData(waveH, accessMode, &dataOffset);<br /> if(ret != 0 ){<br /> // throw here someting if you want to have it more C++-ish<br /> return NULL;<br /> }<br /> <br /> dataPtr = reinterpret_cast<T*>( reinterpret_cast<char*>(*waveH) + dataOffset );<br /> return dataPtr;<br /> }<br />
