AutoScaler Panel for Table Column
jjweimer
// Creates a panel with a checkbox and value display // Checking the box will auto-scale a wave in the first // column of a table by factors in orders of magnitude // Put in procedure window and type AutoScaler() to show panel // Must have an active table with the first column as a numeric wave Function AutoScaler() NewPanel /W=(292,129,494,204) as "AutoScaler" CheckBox scaleit,pos={12,16},size={173,19},proc=CheckProc,title="Auto-Scale 1st Column" CheckBox scaleit,fSize=14,value= 0 ValDisplay scalefactor,pos={18,41},size={150,20},title="Scale x10^",fSize=14 ValDisplay scalefactor,limits={0,0,0},barmisc={0,1000},value= #"1" return 0 end Function CheckProc(cba) : CheckBoxControl STRUCT WMCheckboxAction &cba string theOne variable itsScale switch( cba.eventCode ) case 2: // mouse up theOne=StringFromList(0,WinList("*",";","WIN:2")) // no table windows active if (strlen(theOne)==0) Checkbox scaleit, value=0 ValDisplay scalefactor, value=_NUM:1 break endif wave theWave = WaveRefIndexed(theOne,0,3) // no waves in table if (!WaveExists(theWave)) Checkbox scaleit, value=0 ValDisplay scalefactor, value=_NUM:1 break endif // first wave is not numeric if (WaveType(theWave,1)!=1) Checkbox scaleit, value=0 ValDisplay scalefactor, value=_NUM:1 break endif // checked or unchecked action if (cba.checked) itsScale = round( log(WaveMax(theWave))) ValDisplay scalefactor, value=_NUM:itsScale else ControlInfo scalefactor itsScale = -V_value ValDisplay scalefactor, value=_NUM:1 endif theWave /= 10^itsScale break endswitch return 0 end
