Find traces that intersect the graph marquee
This snippet shows a function that will examing the named graph and return a list of all traces that have points that fall within the graph marquee. Note that the traces must have points in the marquee, it's not enough that they intersect the marquee. The snippet handles the standard additive offset. I have not tried it on log axes. As written, it handles only the left and bottom axes.
#include <Graph Utility Procs>
// Make a list of all traces that have points that fall within the marquee
Function/S ListTracesInMarquee(graphname)
    String graphname
    String tlist = TraceNameList(graphname, ";", 1)
    Variable ntraces = ItemsInList(tlist)
    Make/O/D/N=4/FREE marqueeX, marqueeY
    GetMarquee/W=$graphname left, bottom
    marqueeY = {V_top, V_top, V_bottom, V_bottom}
    MarqueeX = {V_left, V_right, V_right, V_left}
    String theList = ""
    Variable i
    for (i = 0; i < ntraces; i += 1)
        String onetrace = StringFromList(i, tlist)
        Wave ywave = TraceNameToWaveRef(graphname, onetrace)
        Wave/Z xwave = XWaveRefFromTrace(graphname, onetrace)
        if (!WaveExists(xwave))
            Duplicate/O/FREE ywave, xwave
            xwave = pnt2x(ywave, p)
        String offsetinfo = WMGetRECREATIONInfoByKey("offset(x)", traceinfo(graphname, onetrace, 0))
        offsetinfo = offsetinfo[1, strlen(offsetinfo)-2]
        Variable xoffset = str2num(stringfromlist(0, offsetinfo, ","))
        Variable yoffset = str2num(stringfromlist(1, offsetinfo, ","))
        marqueeY -= yoffset
        marqueeX -= xoffset
        FindPointsInPoly xwave, ywave, marqueeX, marqueeY
        marqueeY += yoffset
        marqueeX += xoffset
        Wave W_inPoly
        if (sum(W_inPoly) > 0)
            theList += onetrace+";"
    return theList
// Example of using ListTracesInMarquee: change the color of all traces that intersect the marquee
Function ColorTracesInMarquee(graphname, red, green, blue)
    String graphname
    Variable red, green, blue
    String tlist = ListTracesInMarquee(graphname)
    Variable i
        ModifyGraph/W=$graphname rgb($onetrace)=(red, green, blue)
