Create Density Matrix From XY Data Points
// NOTE: This is experimental - not thoroughly tested.
//	CreateDensityMatrix(xw, yw, numXElements, numYElements, matName)
//	xw and yw contain the location of stars in a galaxy.
//	We want to create a contour plot of the density of stars.
//	To create a contour plot we first need to create a matrix whose X and Y
//	values cover the range of data in xw and yw and whose Z values count
//	the number of stars in a given box (pixel) in the matrix.
//	Example:
//		Make/O/N=10000 xData=gnoise(1), yData=gnoise(1)
//		CreateDensityMatrix(xData, yData, 100, 100, "densityMat")
//		NewImage densityMat
//		AppendMatrixContour/T densityMat
Function CreateDensityMatrix(xw, yw, numXElements, numYElements, matName)
	Wave xw, yw
	Variable numXElements			// Number of X elements in output matrix
	Variable numYElements			// Number of Y elements in output matrix
	String matName					// Name to use for output matrix
	// Make matrix with specified number of X and Y elements.
	// NOTE: This overwrites an existing wave with the specified name.
	Make/O/N=(numXElements,numYElements) $matName
	Wave mat = $matName			// Create wave reference for the matrix
	mat = 0
	WaveStats/Q xw				// Find the X range
	Variable xMin = V_min
	Variable xMax = V_max
	Variable xSpan = xMax - xMin
	WaveStats/Q yw
	Variable yMin = V_min
	Variable yMax = V_max
	Variable ySpan = yMax - yMin
	// Set the X and Y scaling of the matrix
	SetScale x xMin, xMax, mat
	SetScale y yMin, yMax, mat
	// Create temporary wave containing the X element number for a given point in the input x wave
	Variable numXPoints = numpnts(xw)
	Make/O/N=(numXPoints) xElementNumbersTemp
	xElementNumbersTemp = round(numXElements*(xw-xMin)/xSpan)
	// Create temporary wave containing the Y element number for a given point in the input x wave
	Variable numYPoints = numpnts(yw)
	Make/O/N=(numYPoints) yElementNumbersTemp
	yElementNumbersTemp = round(numYElements*(yw-yMin)/ySpan)
	Variable xElement, yElement
	for (xElement=0; xElement<numXElements; xElement+=1)
		Variable xEl = xElementNumbersTemp[xElement]
		for (yElement=0; yElement<numXElements; yElement+=1)
			Variable yEl = yElementNumbersTemp[yElement]
			mat[xEl][yEl] += 1
	KillWaves/Z xElementNumbersTemp, yElementNumbersTemp
cazalets
Dear Sir, I am a very lamdad Igor user and I need to plot density coloured plots. Your procedure appears to me adquate in order to build from my xy data the matrix that will fit them. However, I don not even know how to incorporate the matrix in one my Igor experiment. Could you give me some advices ? Thank you in advance for your consideration. Yours sincerely Jean-René Cazalets
johnweeks
There is also a WaveMetrics Procedure, Bivariate Histogram 2. To use it, add this line near the top of the Procedure Window:
#include <Bivariate Histogram 2>
Then close the Procedure Window. Now you will find under the Macros menu, an item "Bivariate Histogram" that leads to a submenu with variations on the theme. The documentation is entirely in the form of comments at the top of the procedure file. To read them, select Windows->Procedure Windows->Bivariate Histogram 2.ipf. The Macros menu items lead to a very simple GUI so that you don't have to type out the function invocation on the command line.
