Easy Multithreading
RGerkin
This project contains a library of functions designed to make multithreading in Igor easy. Furthermore, it allow you to use your existing functions, with little or no modification, in multithreaded data analysis, greatly increasing throughput.
Project CVS: | http://svn.igorexchange.com/viewvc/packages/multithreader/ |
multithreader IGOR.6.20.x-1.x-dev
Release File: | multithreader-IGOR.6.20.x-1.x-dev.zip (4.25 KB) |
Version: | IGOR.6.20.x-1.x-dev |
Version Date: | |
Version Major: | 1 |
Version Extra: | dev |
Release Notes: |
****This is only compatible with Igor >= 6.2**** Multithread the fast and easy way! Documentation provided in the procedure file. |
