print ROI coordinates in 2D image plots using the Marquee tool as input device
harneit
Menu "GraphMarquee" "Print Image ROI" End Function PrintImageROI() // 1. get the marquee in point units (axis units directly accessible only for 1D graphs!) // sanity test: let there be exactly one image String TopGraphImages = ImageNameList("",";") if( ItemsInList(TopGraphImages) != 1 ) Print "There is either no image or more than one on the graph" return -1 endif GetMarquee // sanity test: was there a marquee at all? if (V_flag == 0) Print "There is no marquee" return -1 endif Variable mpL = V_left, mpR = V_right, mpT = V_top, mpB = V_bottom // print "marquee in points (left, top, right, bottom) =", mpL, mpT, mpR, mpB // 2. get the plot area in point units GetWindow kwTopWin, psize Variable ppL = V_left, ppR = V_right, ppT = V_top, ppB = V_bottom // print "plot area in points (left, top, right, bottom) =", ppL, ppT, ppR, ppB // 3. get the axis limits // get limits of axes that image is displayed against String theImage = StringFromList(0, TopGraphImages) String XAxis = StringByKey( "XAXIS", ImageInfo("", theImage, 0) ) String YAxis = StringByKey( "YAXIS", ImageInfo("", theImage, 0) ) String XAxisLimits = StringFromList(2, StringByKey( "SETAXISCMD", axisinfo("", XAxis) ), " " ) String YAxisLimits = StringFromList(2, StringByKey( "SETAXISCMD", axisinfo("", YAxis) ), " " ) // order left/right correctly, remember whether a swap occurred Variable axMin = str2num( StringFromList(0, XAxisLimits, ",") ), axMax = str2num( StringFromList(1, XAxisLimits, ",") ) Variable paL = min(axMin, axMax), paR = max(axMin, axMax), xSwap = (paL != axMin) // order top/bottom correctly, remember whether a swap occurred axMin = str2num( StringFromList(0, YAxisLimits, ",") ); axMax = str2num( StringFromList(1, YAxisLimits, ",") ) Variable paT = max(axMin, axMax), paB = min(axMin, axMax), ySwap = (paB != axMin) // print "plot area in axis units (left, top, right, bottom) =", paL, paT, paR, paB; print xSwap, ySwap // 4. express the marquee coordinates in axis units Variable maL = paL + (mpL - ppL) * (paR - paL)/(ppR - ppL), maR = paL + (mpR - ppL) * (paR - paL)/(ppR - ppL), swap if( xSwap ) swap = maL; maL = maR; maR = swap endif Variable maT = paT + (mpT - ppT) * (paB - paT)/(ppB - ppT), maB = paT + (mpB - ppT) * (paB - paT)/(ppB - ppT) if( ySwap ) swap = maT; maT = maB; maB = swap endif print "marquee in axis units (left, top, right, bottom) =", maL, maT, maR, maB End
Thanks a lot for writing this, it was just what I was looking for. I do have a slight amendment to make though. Where you get the axis limits from the "SETAXISCMD", if the image axes are set to auto the returned string i.e. XAxisLimits is "" and the returned marquee values are NaN. I have made the following changes to avoid this:
Cheers!
May 29, 2012 at 09:51 am - Permalink
