Igor Pro 9.03 Released
Created on October 25 at 11:18 am - by: aclight
A new release of Igor Pro 9 is now available for all platforms. A list of notable changes for this release is included below. Go to the Downloads page or select the Help→Updates for Igor Pro menu item within Igor Pro 9 to get the latest release. If you've reported an issue to us and we've told you it's been fixed, the fix will be included in this release, even if it's not mentioned below.
Macintosh users: When you drag the Igor Pro 9 Folder from the new installer into your Applications folder, the OS may ask you whether you want to merge the folders or replace the existing folder. You should select "Replace".
Notable Changes in Igor Pro 9.03
Please see the Igor Pro 9.03 Beta 1 release announcement for additional changes compared to Igor Pro 9.02.
IGOR APPLICATION
CHANGED BEHAVIOR
- SavePICT/SNAP can save a subwindow screen capture, and sets S_Name to the name of a picture saved to the Picture Gallery. If /O is not specified and as "<name of pict>" isn't specified, the picture is saved using a unique name of the form Pict0, Pict1, etc. Previously not specifying the as "<name of pict>" would always save (attempt to save) the picture as Pict0, which (without /O) would generate an error if Pict0 already existed.
- File loading operations (XLLoadWave, SoundLoadWave, JCAMPLoadWave, MLLoadWave, and GBLoadWave) now preset the values of all or most output variables before execution. This means that V_Flag will be initialized to 0 even if the operation presents a file loading dialog and the user cancels the dialog. Previously, V_Flag would have been left unchanged from any previous value in this situation. XLLoadWave clears S_value only when /J is specified.
BUG FIXES
- When an if-endif statement calls a routine that executes Abort or AbortOnValue, Igor 9.03 no longer fails to completely abort command execution. Prior to this fix lines of code after the if-endif would execute.
- Fixed a table bug introduced in 9.03 Beta 1. When typing in the text entry area, the first keystroke was often discarded.
- Fixed display of wave names in the debugger when the names contained non-ASCII characters.
- Fixed inability to move a free wave into a free data folder from a preemptive thread.
- Fixed a bug in Gizmo surface top and bottom color alpha.
- Fix for ImageRotate dialog with chunk inputs.
- Fixed crash when killing a panel if one control has an action proc that runs in response to the kill event and which kills a different control.
- Fixed uncommon crash introduced in 9.03 Beta 1 that could be triggered when a global wave was moved into a free data folder and then deleted.
