Igor Pro 9.01 Released
Created on July 19 at 10:14 am - by: aclight
A new release of Igor Pro 9 is now available for all platforms. A list of notable changes for this release is included below. Go to the Downloads page or select the Help→Updates for Igor Pro menu item within Igor Pro 9 to get the latest release. If you've reported an issue to us and we've told you it's been fixed, the fix will be included in this release, even if it's not mentioned below.
Macintosh users: When you drag the Igor Pro 9 Folder from the new installer into your Applications folder, the OS may ask you whether you want to merge the folders or replace the existing folder. You should select "Replace".
Notable Changes in Igor Pro 9.01
Please see the Igor Pro 9.01 Beta 1 release announcement for additional changes.
IGOR APPLICATION
NEW FEATURES
- Added the ability to save HDF5 enum data using HDF5SaveData. See Saving HDF5 Enum Data for details.
BUG FIXES
- Fixed possible crash when compiling an independent module.
