Igor Pro 7.08 Released
Created on January 31 at 02:16 pm - by: admin
A new release of Igor Pro 7 is now available for all platforms. A list of notable changes for this release is included below. Go to the Igor Pro 7 product page or select the Help→Updates for Igor Pro menu item within Igor Pro 7 to get the latest release. If you've reported an issue to us and we've told you it's been fixed, the fix will be included in this release, even if it's not mentioned below.
Macintosh users: When you drag the Igor Pro 7 Folder from the new installer into your Applications folder, the OS may ask you whether you want to merge the folders or replace the existing folder. You should select "Replace".
Notable Changes in Igor Pro 7.08
IGOR APPLICATION
BUG FIXES
- Fixed crash that occurs when clicking a user-defined control that calls a structure-based action procedure after procedures are recompiled. See Control Structures for examples. This bug occurs only in Igor 7.07, and is serious enough to warrant an immediate update.
- Fixed bug where TileWindows sometimes returned an error if a procedure window was visible.
