Igor Pro 7.02 Released
Created on January 27 at 01:48 pm - by: JimProuty
A new release of Igor Pro 7 is now available for all platforms. A list of notable changes for this release is included below. Go to the Igor 7 Downloads page or select the Help→Updates for Igor Pro menu item within Igor Pro 7 to get the latest release. If you've reported an issue to us and we've told you it's been fixed, the fix will be included in this release, even if it's not mentioned below.
Macintosh users: When you drag the Igor Pro 7 Folder from the new installer into your Applications folder, the OS may ask you whether you want to merge the folders or replace the existing folder. You should select "Replace".
Notable Changes in Igor Pro 7.02
Please see the Igor Pro 7.02 Beta 1 release announcement for a list of changes made prior to release of the beta. In addition, the following changes were made after the beta was released:
IGOR APPLICATION
BUG FIXES
- Fixed a problem in which synced Gizmo plots kept marking an experiment as changed (enabled Save Experiment menu item).
- Fixed a bug in StatsResample where WaveStats results were not set in the V_xxx variables when performing no iterations.
