Igor Pro 9.02 Beta 1 Released
Igor Pro 9.02 Beta 1 has been released. For more information, see the release announcement at https://www.wavemetrics.com/news/igor-pro-902-beta-1-released.
I'll highlight one important point mentioned in the release announcement:
New Signing Certificate
This is the first official beta release of Igor Pro since Sutter Instrument purchased WaveMetrics in September 2022. Due to how the purchase was executed, WaveMetrics was required to get new code signing certificates for both platforms, and these new certificates are used starting with this release.
Windows users should notice no change in behavior.
Macintosh users may notice that the OS asks you to re-authorize Igor to view protected folders (e.g., Documents, Desktop, etc.) and to control other applications. Unfortunately, some of these prompts come the first time you use Igor to do something protected, not the first time you run Igor. You can get around the file and folder access prompts by granting this version of the "Igor64" application Full Disk Access in the Privacy tab of the Security & Privacy section of System Preferences. A similar workaround for automation access does not seem possible since there is a separate permission for automation control of each application.
To be clear, this version of Igor doesn't need any new permissions compared to older versions. The issue is that a different corporate entity is associated with Igor's code signing certificate, and this triggers the OS to ask for permissions again.
If you use Igor on macOS to do unattended tasks, we recommend that you try running those tasks while attended in case you need to click through any macOS security prompts.
