Simple syntax exception to plot many points against one?
gsb
here's an example of the syntax I'm thinking of:
make/o/n=(3,3) mydata SetDimLabel 0,0,time0val,mydata; SetDimLabel 0,1,time1val,mydata;SetDimLabel 0,2,temperature,mydata; SetDimLabel 1,0,condition0,mydata;SetDimLabel 1,1,condition1,mydata;SetDimLabel 1,2,condition2,mydata; mydata={{-1,10,33},{-0.5,11,35},{-2,12,37}} display/k=1 mydata[1][*] vs mydata[2][(] //a normal use display/k=1 mydata[0,1][0] vs mydata[2,*;0][0] //Wish this worked! (Surprisingly, there is no error. However, it plots starting from a row index for the x-values that is not 2.)
This syntax would alleviate the need -- unless there are alternatives that I should consider (?) -- to create extra wave points (redundantly containing the same data) serving as placeholders for the repeated x value.
January 17, 2018 at 04:59 pm - Permalink
But since the latitude parameters are constant within each group, you could also store the data as follows, without as much redundancy. The only issue is that I don't believe that one can make the same plot of the data in any straightforward way (though you could probably get close with offsets and muloffsets, for instance)
A category plot would be fine for this simple two group situation, but imagine if you had measurements from hundreds of latitudes, as well as more data like the temperature at each latitude. This syntax would help to avoid (unnecessarily) replicating data, which then has to be kept organized. I find myself wanting to plot this way fairly often.
January 18, 2018 at 06:53 am - Permalink
Extract
.January 18, 2018 at 07:56 am - Permalink
To my mind, the extent to which that becomes a problem depends on the dataset's size (e.g., how many different groups) and complexity (e.g., how many different parameters are measured for each group).
January 18, 2018 at 08:47 am - Permalink
In addition, you can request "jitter" for the data points to spread out overlapping points. That way, these plots can also to some degree replace the Scatter Dot Plot package.
January 18, 2018 at 03:15 pm - Permalink
While this is not as smart as the ScatterDotPlot Package, it has the advantage to maintain the order of the datapoints. I needed this because I had to make a scatter dot plot were the datapoints in the individual waves corresponded to each other. The first datapoint in wave1 should have the same symbol as the first datapoint in wave2 etc.
Greetings,
Klaus
January 19, 2018 at 12:56 am - Permalink
(Still think it would be really nice if increments of zero were supported. Shouldn't it at least throw an error otherwise?)
January 19, 2018 at 06:40 am - Permalink
