Improving the /Z flag of Wave, NVAR, SVAR
thomas_braun
1.) Currently the /Z of the above operations doesn't recognize dfrefs which are null and are supplied by /SDFR.
For example the following is my current way in referencing global vars in some of my procedures.
if(!DataFolderExists(settingsFolder)) print "BUG: settings folder does not exist" return 0 endif NVAR/Z/SDFR=$settingsFolder scrapFormatOne, scrapFormatTwo, hddFormatOne, hddFormatTwo, exportLowRes, exportHighRes if(!NVAR_Exists(scrapFormatOne) || !NVAR_Exists(scrapFormatTwo) || !NVAR_Exists(hddFormatOne) || !NVAR_Exists(hddFormatTwo) || !NVAR_Exists(exportLowRes) || !NVAR_Exists(exportHighRes)) print "BUG: some nvars are missing" return 0 endif
I always have to check that the datafolder exists before I pass it to the /SDFR flag. In my eyes the /Z flag should also prevent run time errors due to invalid /null dfrefs in the /SDFR flag.
The following example shows hopefully what I mean:
#pragma rtGlobals=3 // Use modern global access method. Function doTest() string folder="root:testing" string folderNonExistent="root:testingNonExistent" NewDataFolder/O $folder dfref folderDFR = $folder dfref folderNonExistentDFR = $folderNonExistent variable/G folderDFR:nvarOne variable/G folderDFR:nvarTwo variable/G folderDFR:nvarThree variable/G folderDFR:nvarFour variable/G folderDFR:nVarFive NVAR/Z nvarOne = $(folder) +":nvarOne" if(NVar_Exists(nvarOne)) print "nvarOne exists" endif NVAR/Z nvarTwo = $(folderNonExistent) +":nvarTwo" if(NVar_Exists(nvarTwo)) print "nvarTwo exists" endif NVAR/Z/SDFR=folderDFR nVarThree if(NVar_Exists(nVarThree)) print "nVarThree exists" endif NVAR/Z/SDFR=folderNonExistentDFR nVarFour // <- runtime error if(NVar_Exists(nVarFour)) print "nVarFour exists" endif KilLDataFolder/Z $folder // now the dfref is still valid but the folder is non existent NVAR/Z/SDFR=folderDFR nVarFive // no run time error, /Z works as expected if(NVar_Exists(nVarFive)) print "nVarFive exists" endif End
2.) It would be also terrific if there would be an easier way to get to know if the last NVAR/SVAR/Wave call with the /Z flag was completely successfull or not.
The idea would be along the lines of
NVAR/Z/SDFR=$settingsFolder scrapFormatOne, scrapFormatTwo, hddFormatOne, hddFormatTwo, exportLowRes, exportHighRes if(!lastRefSuccess()) // or a V_flag print "BUG: some nvars are missing" return 0 endif
Thanks for reading,
Thomas
