Gizmo commands should appear in the command window
joerg.kunze
it would be very helpful, to see the Gizmo commands appear in the command window. Because, then I can directly use them for scripting.
Regards,
Jörg.
It would be useful indeed. This would probably happen once Gizmo is integrated into the main application.
September 25, 2009 at 01:39 pm - Permalink
And how would one go about doing this?
Jon
May 8, 2013 at 08:32 am - Permalink
The short answer is: Very carefully :)
I think you missed my point: Gizmo in IP6 is an XOP and as such there are limits on the level of its integration with the main application. The change is a huge job and not something that the end user could/should worry about. FWIW, as part of the transition to IP7 Gizmo has been completely integrated into IGOR and its dialogs spit up more command lines than you would care to type from scratch.
May 8, 2013 at 09:48 am - Permalink
Jon
May 8, 2013 at 10:32 am - Permalink
