Hello, I'm new to Igor programming, so the following is probably a very simple problem. I'm also not very good at programming, so I apologize if the code below is a little naive/crude. I have a matrix named, RD7_Efield_490V, which is a 116 row by 60 column matrix. I also have a wave named, CorrectionFactor, which has 116 rows. I want the first value in row 0 of CorrectionFactor to be multiplied by each element in row 0 of matrix RD7_Efield_490V. Then the second value in row 1 of CorrectionFactor to be multiplied by each element in row 1 of matrix RD7_Efield_490V. When its all done, I would like a new matrix RD7_Efield2_490V, with the same # of rows and columns as RD7_Efield_490V. When I run the code below, I only get one value in the RD7_Efield2_490V matrix (which is incorrect in value, so I'm not quite sure what got multiplied with what). What I tried is in the attached file (I couldn't get it to fit in the post).
Thanks in advance for your help!
The programming is only one of the issues here, it is your problem description that needs improving.
Your explanation implies only 2 for/end for loops, yet your code has 3.
Your explanation says "I want the first value in row 0 of Correction Factor", yet there is only one value in row 0 of the Correction Factor wave, since it has 116 rows and no columns are mentioned nor are they indexed in your code.
Taking a wild guess, do you actually want to multiply each column of your RD7_Efield_490V matrix by the CorrectionFactor vector?
That would simply be:
RD7_Efield_490V *= CorrectionFactor[p]
which modifies the wave in-place.
If you want a new wave to hold the result, you need another wave name:
I put your attachment here between <igor> and </igor> tags for easy reference:
Thanks, I'll know that for next time.
I suppose what had me confused is that I was working with the numbers across each row. These matrices where images that I had loaded into Igor, and I was working calculations down a column of pixels, but looking at the digitized values of the image in Igor, that column was actually a row in the table (hopefully that made sense). Either way, what you said helped, only that:
RD7_Efield_490V *= CorrectionFactor[q]
It was q that I needed and not p. Thanks again! Will try to explain better next time.
Wave RD7_Efield_490V, CorrectionFactor
Variable kfactor = DimSize(CorrectionFactor,0)
Variable numRows = DimSize(RD7_Efield_490V,0)
Variable numCols = DimSize(RD7_Efield_490V,1)
Variable i,j,k
for(i = 0;i<kfactor;i+=1)
for(j=0;j<numRows;j+=1)
for( k=0;k<numCols;k+=1)
MatrixOP/O RD7_Efield2_490V = CorrectionFactor[i]*RD7_Efield_490V[j][k]
END
Duplicate/O RD7_Efield_490V, RD7_Efield_490V_Corr
RD7_Efield_490V_Corr= RD7_Efield_490V * CorrectionFactor[p]
June 9, 2011 at 11:57 am - Permalink
June 9, 2011 at 12:18 pm - Permalink
