When does help broswer appear vs. documentation?
Sometimes when I right click on a defined function in a procedure, like "make", and then select Help for make, I go directly to the documentation. And sometimes, although I don't feel I've changed anything, I get the Help Browser. I immensely prefer the documentation, since what I usually need is specifications for a flag or something. How can I insure that it's the documentation, not the help browser, which appears?
On Windows, if the command in question is documented for an XOP, the help browser will appear.
[quote]On Windows, if the command in question is documented for an XOP, the help browser will appear.[/quote]
Macintosh too.
[quote]How can I insure that it's the documentation, not the help browser, which appears?[/quote]
To open the help file for an external operation or function, execute:
DisplayHelpTopic "<name>"
I tried it for the "make" command. Shouldn't a help file (not the help browser) open when I select Help for make? I'm using a Macintosh.
Any ideas why the help browser is showing up?
Just realized, I had closed the Igor Reference.ihf. So when I select "Help for make" it is taking me to the Help Browser, instead of opening a new Igor Reference.ihf.
Can I make "open new Igor Reference.ihf if not already open" default?
[quote]Can I make "open new Igor Reference.ihf if not already open" default?[/quote]
No. I recommend that you leave the Igor Reference file open.
Note that clicking the close box on a help file hides the file. To close it you have to option-click or alt-click the close box.
It would not be practical; that means it would take a very long time for any incorrectly typed command to be reported as incorrect if we each time searched for inadvertently-closed help files.
"Hide Window" is your friend.
