What is the best way in Igor to toggle single bit
euaruksakul
Hi
I am programming to automatically select a row in ListBox (mode=3) using SelWave which uses an integer to define/read status of each row, but still cannot figure out If I want to modify bit 0 regardless of other bits. What is the best way to do it?
Thank you very much.
Chanan
I have posted a code snippet at https://www.wavemetrics.com/node/20939
June 5, 2019 at 08:01 am - Permalink
Thank you very much!
Chanan
June 6, 2019 at 03:30 am - Permalink
