Weird rounding?
I have a piece of code that has a series of "if" statements, and in half of the instances, a calculated value (lets call it Q) is assigned to a variable (x).
Later in the code as a boolean check, I have the code do "if (x-Q <=0)" or something along those lines. X was assigned the value Q earlier. However, when this operation takes place, abs(q-x) does not equal 0! it usually equals something between -10,10. Q by itself is a value that is something like this 7.5*10^7. So the numbers being subtracted are x(7.5*10^7) - Q(7.5*10^7) and it is not equalling 0. I'm sure it has to do with sig figs and the precision, but, without sharing my code, is there an obvious solution to these rounding weirdities?
Just a question - why do you need to check
if (x-Q <= 0)
when you know that you have previously setx = Q
?What I usually do, when I want to check whether two variables are (close) to the same value, is that I calculate (using your variable names)
abs(x/Q-1)
and then allow for a small offset from1
(due to possible floating point rounding error, or allow for some variation in the values of the variables, etc.), i.e.if ( abs(x/Q-1) > 1e-5)
where the value1e-5
would need to be chosen appropriately ...But probably there are other (better) ways to do that ...
Gregor K
ALOISA Beamline
Elettra Synchrotron
July 31, 2017 at 11:52 pm - Permalink
if (abs((A-B)/A) < 1-6)
or something similar. Also be careful with using x and q, since they both have special meanings in Igor.August 1, 2017 at 04:25 am - Permalink
indeed, you don't get back what you think you put in because of floating-point truncation. Another surprise is a loop:
The output is like this:
i= 0
i= 0.1
i= 0.2
i= 0.3
i= 0.4
i= 0.5
i= 0.6
i= 0.7
i= 0.8
i= 0.9
i= 1
But, wait! I said
i<1
, noti<=1
! The trick is that 0.1 cannot be exactly represented as a floating-point value; it is an infinite fraction. Here is another look at the problem:Now the output is:
i = 0
i = 0.100000000000000006
i = 0.200000000000000011
i = 0.300000000000000044
i = 0.400000000000000022
i = 0.5
i = 0.599999999999999978
i = 0.699999999999999956
i = 0.799999999999999933
i = 0.899999999999999911
i = 0.999999999999999889
Now you can see that it does, indeed, stop at less than 1.0!
Notice that 0.5 is exactly represented. It is a power of 1/2, so it can be represented exactly with a binary number. You will get what is expected if you increment by 0.25, another integer power of 1/2.
See https://docs.oracle.com/cd/E19957-01/806-3568/ncg_goldberg.html
The article is called "What Every Computer Scientist Should Know About Floating-Point Arithmetic" but these days, it should just say "scientist". Virtually every scientist these days is using a computer, and will run into floating-point truncation errors some day.
August 1, 2017 at 02:35 pm - Permalink
Johnweeks, I had specified the waves as /d previously. THank you for all the extra info. very helpful
August 1, 2017 at 02:40 pm - Permalink
Note that here the loss of precision has crept up into the region of 5 parts in 10^6, even though the original numbers have precision of somewhere around 1 part in 10^17.
August 2, 2017 at 09:28 am - Permalink
Ultimately, I'd try entirely to avoid comparisons of floating point values in the code. Instead, I'd set a (boolean) flag at the exact point when Q is set to the (supposedly constant) variable. Later, I would test for the truth of the boolean flag. Something like this ...
August 4, 2017 at 01:10 pm - Permalink
Great!
August 15, 2017 at 02:27 am - Permalink
