    Wave modification
I have been reading several examples from Payam’s place and also the introduction notes on Programming from the manual but I think I have not got the grip of the basics of Igor yet. Essentially, I would like to process several curves, typically named in a systematic fashion, do something to them, get the result and store it in a wave. While I am aware of several of the functions, to incorporate it in something like a script likely requires a type of thinking I am not accustomed to.
I wonder if anyone could help me with a simple practical problem which I think can help me to understand the workings of Igor:
I have a set of waves each containing a single peak. The name of the waves have the following format:”string1””string2”, where is the number of the waves within the series. For each wave, = 0, 1, 2 ... I would like to normalize it using the peak average which I have stored in another wave (AveragePeakAmp) and subsequently subtract the background using wavemin. Having done that, I would like to save the new waves with a different name.
Can anyone help me?
Many thanks to all!!
R.
For this to work your AveragePeakAmp wave has to match the wavelist order. The way this is written, it will not check this. Without knowing a bit more detail it's difficult to prevent an error.
Also, just to say that I would subtract the minimum value, find the peak and then normalise to that value, giving a scale of 0 to 1. You didn't request this and wanted to subtract afterwards.
April 15, 2015 at 09:17 am - Permalink
Cheers,
R.
April 16, 2015 at 10:06 pm - Permalink
