Using waves from a folder in a function running in root
I request advice on the following situation:
I have a folder "X" (address is root:X) that contains a set of waves.
Now I have a function running in the root: that needs to use the waves contained in folder X.
I think this isn't a complex problem but I couldn't get hold of the syntax..
I am calling the waves in the function using WAVE, hoping this would turn them global and thus would run within the function. However, it doesn't work. The function returns error saying it's trying to operate on a missing wave.
Kindly advise how I could make a function that is running in root: use waves that are located in a folder.
Many thanks,
Peeyush
Oops I think I just figured it out. Here is what I did:
setdatafolder root:X
WAVE wave1,wave2,wave3....
setdatafolder root:
Function()
In case if someone knows a more efficient way, kindly let me know. My problem was that I was not setting the data folder to X before calling WAVE.
October 28, 2020 at 08:06 pm - Permalink
It's better to use the /SDFR flag with wave, rather than changing the data folder.
DisplayHelpTopic "The /SDFR Flag"
In general, if you can avoid changing data folder within a function that's for the best. If your code exits unexpectedly, or you don't take account of some pathway in your code that doesn't reset the data folder, you will leave the user in an unexpected data folder, which is confusing and will likely break your code.
What you did should work fine, though.
October 29, 2020 at 12:30 am - Permalink
October 29, 2020 at 03:38 am - Permalink
An example showing Tony's suggestion. If the folder containing your waves is "root:MyFolder" which contains wTest and wTest2 waves --
October 29, 2020 at 06:37 am - Permalink
Wow the DFREF /SDFR syntax worked swimmingly well! Thanks a lot, guys. I was being driven to the brink of insanity sorting the overpopulated root folder since my experiment/program is over 600 MBs in size and more than 10,000 lines of code. Learned something very new today with the DFREF /SDFR. I greatly appreciate the help and advice!
October 29, 2020 at 09:30 am - Permalink
