trouble with savePICT
ychen344
I was wondering if I can get your inputs on the following problem.
In a program, I need to output 2 layouts as .jpeg (E=-6)
SavePICT/EF=1/P=home/E=-6/WIN=layout0 as patient_number+"_"+patient_ID+"_"+testDate+"_01"
SavePICT/EF=1/P=home/E=-6/WIN=layout1 as patient_number+"_"+patient_ID+"_"+testDate+"_02"
However, the program always output two files (not sure what format they are) when I run the first time. Running gain will output the .jpeg file correctly.
Judy
You need to include the file name extension with the file name parameter.
I would do it like this which is easier to read and debug:
April 27, 2020 at 02:35 pm - Permalink
Problem solved. Thank you!
April 27, 2020 at 02:49 pm - Permalink
