Trouble with For-Loop
vmmr5596
I wrote a little procedure that is supposed to subtract a wave from another for a set of data.
My dataset kinda looks like this:
a_wave0,a_wave1,a_wave2, etc
b_wave0,b_wave1,b_wave2,etc
What I want to accomplish is subtract b_wave0 from a_wave0, b_wave1 from a_wave1, etc. However, the final results don't seem to make sense. When I look at the debugger, it appears that that the loop is doing something like this:
b_wave0 from a_wave0, b_wave0 from a_wave1, b_wave0 from a_wave2, etc.
I was thinking that including an "if" statement within the loop might help, but I'm not quite sure how to do it.
Here is the procedure I wrote:
#pragma rtGlobals=3 // Use modern global access method and strict wave access. Function AmorphousSpectra(w1,w2) //Determines amorphous spectra by subtracting Spano fit from total spectra WAVE w1,w2 //w1=TotalSpectra and w2=Spano Fit String outputName= NameOfWave(w1)+"_A" Duplicate/O w1 $(outputName) Wave output = $(outputName) output = w1 - w2 End Function AmorphousAll(w1,w2,fnum) //To use it do not include any numbers or _bl_smth in the name STRING w1,w2 Variable fnum Variable i //The initial values of i and j should be adjusted based on the numbers present in the original names of the wave Variable j String neww1,neww2 for(i=16; i<=fnum;i=i+1) neww1= w1 +num2str(i)+"_bl_smth" for(j=16; j<=fnum;j=j+1) neww2= w2 +num2str(j) +"_bl_smth" AmorphousSpectra($(neww1),$(neww2)) endfor endfor End
Thanks for any suggestions/help!
August 1, 2016 at 04:35 pm - Permalink
