Is there a 'best' way to exit functions?
pokeeffe
For errors, a simple Abort with message seems appropriate. For 'Cancel' buttons, I can't decide which is better - perhaps return is so that calling functions have a chance to continue? Does anyone have a good understanding of why you might choose one over the other?
// typical exit if user cancels DoPrompt If (V_flag) return -1 // returns -1 endif // quicker exit AbortOnValue V_flag, -1 // returns NAN // need to return user home If (V_flag) SetDataFolder sav0 return -1 // this one //AbortOnValue 1, -1 // or this one? endif
For other situations, you should return an error code that the calling routines can interpret. We use 0 to mean success and non-zero to mean failure. -1 is usually used to mean cancel. The calling routine can then decide whether to retry, abort or return the error code to its calling routine.
April 1, 2011 at 08:06 pm - Permalink
April 2, 2011 at 02:28 pm - Permalink
If I want to alert the user to a problem, I'll use DoAlert to present a simple message, and then use Howard's idea of returning a simple success/fail/cancel value.
I haven't used Abort for 15 years.
April 2, 2011 at 10:41 pm - Permalink
I partially agree, partially disagree with this. I'd deepen your statement to say that Abort should never be part of any program flow that you expect the user to reach. That means that, if your program executes perfectly (no bugs), no Abort statements should ever be executed.
I tend to sprinkle quite a few Abort statements into my code to aid me in catching possible bugs. Basically, if I know that something should never occur, then I'll add in that case and have it trigger an Abort statement. An example here would be adding a default statement in a switch statement even where I don't expect one to be necessary. Example:
The idea here is that, when my program enters undefined territory, I would like it to blow up as soon as possible and as irreversibly as possible.
April 3, 2011 at 05:57 pm - Permalink
741, that's an excellent idea for catching bugs - simple & informative!
April 4, 2011 at 01:54 pm - Permalink
If I'm developing code that I plan to not give to anyone else, I'd be okay with that. But code the user "should never reach" has a way of reaching users. So I'd rather use:
Remember, Abort alters the control flow, often in ways that may surprise you.
April 5, 2011 at 02:18 pm - Permalink
