Style-"Bug" in tick labeling (axis)
HJDrescher
Creating a graph with the unit in the label, it "sticks" to the number (against the SI guidelines, which recommends a blank between value and unit *in most cases*):
http://physics.nist.gov/cuu/Units/checklist.html
make test=((x-60)/120)^2 setscale x,0,1e-6,"m", test display test label bottom "Distance"
I could define a blank in the unit but lose the prefix feature (and actually I want to keep it -- in some cases it might result in "k nm", see [#6548]).
The \U \u \u#2 options don't work in my case.
I have two correlated x axes for the same quantity in two units (Coverage in "ML" and in "m")
HJ
PS: an exception would be angular degrees "42°" (but "42 °F" ...)
On thing you can do in cases like this is to suppress the tick and draw your own using an axis tag. Here is an example using the test code above
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
August 1, 2015 at 07:30 am - Permalink
The next (tomorrow's) nightly build will have this change. You can get the nightly build here:
http://www.wavemetrics.net/Downloads/latest/
In the unlikely event that someone prefers the old way, I'll have to add an option keyword.
Larry Hutchinson
WaveMetrics
August 1, 2015 at 08:34 am - Permalink
Thank you!
HJ
August 2, 2015 at 07:45 am - Permalink
