String to ASCII
Hi at All,
I wuold like to convert a string of characters in ASCII values.
So I made a function using SSCANF:
Function/S str2ASCII(tmpstr)
    String tmpstr
    String tmpASCII
    Variable i=0, tmp, num=strlen(tmpstr)
    For (i=0;i<num;i+=1)
    sscanf tmpstr[i], "%c", tmp
    tmpASCII+=num2str(tmp)
return tmpASCII
So I check the function and It works. When I use the function:
String test
String test2
test2="Hello"
test=str2ASCII(test2)
"Attempt to use a null string variable" appears and this message "Missing text resource for error: 0" appears on the command line.
Where is the error? Because If I add print command in the function, a right result appears.
Thanks in advance.
Matteo
Try this
    string tmpstr
    string tmpASCII="" // required declaration here, otherwise string is NULL
    variable i, tmp, num=strlen(tmpstr)
    for (i=0;i<num;i+=1)
        return tmpASCII
which gives
print str2ascii("Hello")
  72101108108111
Here is a solution that does not use sscanf:
Function/S Str2ASCII(str)
    string str
    String result = ""          // Initialize to empty string
    Variable i, count=strlen(str)
    for (i=0;i<count;i+=1)
         String ch = str[i]
         Variable num = char2num(ch)
         result += num2str(num)
    return result
