Solving numerical integral
I would like to ask someone's help to get more accurate solution for an integral.
I have a data set which should be integrated with the given integral (see picture).
So far, I solved this problem like this:
1. Precalculated the derivative
2. than use a simple rectangular integration to compute the integral
The problem is the results contains some negative error because the first point is not considered.
(between t=z and t1)
I did not found any way to use the Igor built in integrals for this problem (I'm new around).
I would like to ask some advice how to move forward.
Thanks a lot!
You should take a look at Integrate1D, which will do a numerical approximation of an analytic integration. You provide an Igor user-defined function that evaluates the integrand. You will need some expression for Omega(t) and d(omega)/dt, or at least an approximation of them.
Yes, I tried to use it but I run in to problems. The omega(t) (measured data at each Z point) is a function of Z of corse. For the hole data set it is difficult
the approximate but what I found is that I can fit with a small proximity of the data with a polynomial function than the expressions for both are easy and I can call the integrate1D.... move the proximity .... finally sum it up. (Of corse this will take kind of long). But no better way at this moment
