Slider won't move continuously in IgorPro 7
ctmckee
Function SliderProc_3(sa) : SliderControl STRUCT WMSliderAction &sa switch( sa.eventCode ) case -1: // control being killed break default: if( sa.eventCode & 1 ) // value set Variable curval = sa.curval setactivesubwindow BGPanel setactivesubwindow #OImage ModifyImage Om ctab= {0,curval,Grays,1} setactivesubwindow BGPanel setactivesubwindow #EImage ModifyImage Em ctab= {0,curval,Grays,1} setactivesubwindow BGPanel endif break endswitch return 0 End
Here is the corresponding Panel code:
Slider SetOriginalScale,pos={6,338},size={300,50},proc=SliderProc_3 Slider SetOriginalScale,help={"Image Scale"},labelBack=(56576,56576,56576) Slider SetOriginalScale,fSize=10 Slider SetOriginalScale,limits={0,255,0},value= 98.8586956521739,vert= 0,thumbColor= (0,65280,0)
Slider SetOriginalScale live=1
? Accordig to documetation this should be the default though.October 8, 2016 at 04:05 pm - Permalink
If you click in the thumb, you can drag the thumb and the control will follow the mouse movement.
This is true in both Igor 6 and 7.
October 10, 2016 at 09:44 am - Permalink
Still no continuous motion with inclusion of
Slider SetOriginalScale, live=1
October 10, 2016 at 09:50 am - Permalink
In my case "If you click in the thumb, you can drag the thumb and the control will follow the mouse movement." does not perform as you note for Igor7, but does in Igor6, for the above noted code.
Clayton
October 10, 2016 at 09:53 am - Permalink
I put a lot of effort into making window activation work correctly in Igor 7, but there are some things that simply are different.
October 10, 2016 at 09:57 am - Permalink
That solved problem.
C
October 10, 2016 at 10:14 am - Permalink
