Setting the filter order of resample/rate function
Sandbo
From my understanding, the resample/rate=(newSampFreq) does all the necessary interpolation and low-pass filtering to implement the decimation.
In my case, it seems like the filter order is too low for me to get a cut-off sharp enough. I could do this with the resample/down flag and supplied a mask from FilterFIR, but this is less convenient as I will have to calculate the up and down for non-integer decimation factor.
Would there be an option to choose the filter order with resample/rate?
Thanks a lot.
Try a larger value for Resample/N=numReconstructionSamples:
August 10, 2018 at 04:59 pm - Permalink
