Set default Initial Guesses in User-Defined Function
Function alpha_EY_Fit(w,d) : FitFunc
Wave w
Variable d
//CurveFitDialog/ d
//CurveFitDialog/ Coefficients 13
//CurveFitDialog/ w[0] = alpha_int
//CurveFitDialog/ w[1] = Ms
//CurveFitDialog/ w[2] = d_FM
//CurveFitDialog/ w[3] = G_ud_1
//CurveFitDialog/ w[4] = lambda_1
//CurveFitDialog/ w[5] = rho_0
//CurveFitDialog/ w[6] = mfp
//CurveFitDialog/ w[7] = sigma_int
//CurveFitDialog/ w[8] = G_ud_2
//CurveFitDialog/ w[9] = lambda_2
//CurveFitDialog/ w[10] = sigma_2
//CurveFitDialog/ w[11] = d_2
//CurveFitDialog/ w[12] = Delta_SML
//initial guesses:
//Ms = 8.4352e+005 A/m
//mfp = 13e-9 m
//rho_0 = 1.6311e-7 ohm*m
//sigma_int = 1.2786e6 ohm^-1 m^-1
//G_ud_2 = 4.79e14 Ohm^-1 m^-2
//lambda_2 = 1e-9 m
//sigma_2 = 3.3e6 ohm^-1 m^-1
return alpha_EY(w[0],w[1],w[2],w[3],w[4],w[5],w[6],w[7],w[8],w[9],w[10],w[11],w[12],d)
Why are you hiding the details of the function alpha_EY(...)? Why not put its code fully inside of alpha_EY_fit so that reading and debugging the code is easier?
September 28, 2017 at 11:49 am - Permalink
How is this done? Do I simply declare the values for each of the elements of Wave w?
Function alpha_EY_Fit(w,d) : FitFunc Wave w Variable d //initial guesses w[0] = .004 //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ d //CurveFitDialog/ Coefficients 13 //CurveFitDialog/ w[0] = alpha_int //... etc. End
Thanks.
As for your other comment, I didn't need to include the complicated form of alpha_EY(...), but you are right. Including it directly would make the code easier to debug.
September 28, 2017 at 12:49 pm - Permalink
[/quote]
Yes, but as this ...
Also, you might also use the above convention to avoid overlap of WaveMetrics definitions (w? or d?) and to help make the code legible.
September 28, 2017 at 02:16 pm - Permalink
DoFit()
?I like using the "Graph Now" functionality as a tweak my initial guesses.
September 28, 2017 at 04:45 pm - Permalink
DoFit()
?I like using the "Graph Now" functionality as a tweak my initial guesses.[/quote]
This will NOT work from a menu call. The option in this case is to define and initialize the coefficient wave using the command line. Then use the menu and select the pre-defined, pre-initialized wave as the coefficient wave. Alternatively, you can
* Learn how to append the initial guess wave to the current graph
* Learn how to include the flags you need in the operation call to CurveFit.
September 29, 2017 at 05:56 am - Permalink
