Selective update of waves displayed in graphs
thomas_braun
I'm displaying large waves (> 10e5 points, up to 8 of them) in a graph. These waves hold scaled data from hardware.
Now everytime I update one of these waves I'm only updating the rows with new data to save time instead of rewriting the whole wave.
Is there a way to tell Igor which parts of the wave changed so that only these parts need to be redrawn?
I'm already manually adjusting the axis ranges only every 25th wave update to save time.
July 26, 2017 at 01:19 pm - Permalink
July 26, 2017 at 02:49 pm - Permalink
this is also what i want to say..:)
July 26, 2017 at 09:25 pm - Permalink
I don't completely understand where/what the hold-up is as I don't completely understand your situation, but maybe splitting the data wave into smaller chunks will work. Then appending all chunks to the graph and updating only the respective chunk/s over which the change has occurred. I don't know how easy that would be.
Also, maybe the "raw" data is not visually needed to be displayed in its entirety, so that it can be decimated by some factor satisfying the condition that the eye cannot distinguish the difference or the difference may be minor.
best,
_sk
July 27, 2017 at 01:21 am - Permalink
Yes I view the data live during data acquisition.
There is no good point for when I'm ready as I want to view it live.
This sounds like an interesting idea. I'll try that.
We thought about that too, but could not come up with a general and reliable decimation approach.
July 27, 2017 at 11:18 am - Permalink
I've now tried that using
This creates a graph with two traces in it. One large wave and a smaller one.
Then I update each of the waves and measure the time it takes for the update.
And I get
•dotest() 0.0290689 s 0.0360801 s
which means it does not matter which wave I change, Igor needs the same amount of time.
July 27, 2017 at 12:30 pm - Permalink
There is one exception: since a graph is actually a bitmap, and re-drawing a graph from the bitmap is quite fast, you can designate a trace as "live" mode. Then the graph's bitmap is drawn to include everything but the live-mode traces, and if a live-mode trace's data changes, the graph is re-drawn by drawing the bitmap to the graph's window followed by drawing the live-mode traces directly to the window. It is the step of first drawing the bitmap of the entire graph that accounts for the restrictions on live-mode traces.
I'm not sure that live mode really helps your situation, though.
July 27, 2017 at 01:02 pm - Permalink
Yeep that is difficult. But a lot of things are difficult yet implemented in Igor ;)
I've tried that and it did not speedup that in my case.
July 27, 2017 at 01:11 pm - Permalink
July 27, 2017 at 01:35 pm - Permalink
July 27, 2017 at 02:08 pm - Permalink
July 27, 2017 at 03:55 pm - Permalink
What are the advantages (i.e. opengl drawing at 60fps) of using the gizmo? Could you explain the advantages?
best,
_sk
July 28, 2017 at 02:25 am - Permalink
Regarding Gizmo I've tried to use it for plain 1D waves before but failed last time I tried. Also the documentation in 3D graphics states "1D waves can not be used for 3D plots. " and I did not dig deeper at that point. So an example would be helpful.
July 28, 2017 at 03:27 am - Permalink
Regular Graph windows display traces subject to a number of constraints that are absent from OpenGL drawing. Graphics hardware is more efficient at accelerating the drawing data that resides in graphics memory as opposed to handing a bunch of OS calls MoveTo() LineTo(), etc. OS calls on both platforms are having trouble with efficiently rendering thick lines on high resolution monitors. OpenGL does not care about this. A unit-width line will be thinner than it would appear in a graph but it would not take two weeks to render the trace. The higher efficiency is more pronounced in rendering images where Gizmo uses optimized textures while Graph windows map pixels to rectangles.
August 1, 2017 at 12:27 pm - Permalink
The documentation is correct but you seem to focus on the wrong part. You do need a triplet wave to display a path in Gizmo. You can set the z column to zero, insert your data into the y column and keep the x in the acquisition units. You then display the path, rotate the graph so that you view it from the top and lock the rotation. Also make sure to start by allocating a very large triplet, fill it x and z as described above and set the y values to NaN. Then during your acquisition update the y values as you go.
August 1, 2017 at 12:35 pm - Permalink
I can't really judge that as I can not measure the time it takes nor can I display mutiple waves at once (the case where the slowdown is measurable).
I'll give Gizmo a shot.
August 4, 2017 at 12:23 pm - Permalink
I can't really judge that as I can not measure the time it takes nor can I display mutiple waves at once (the case where the slowdown is measurable by just looking at it).
August 5, 2017 at 02:53 am - Permalink
