Scaling waves for long ranges on log axis plots
I am trying to generate a theoretical curve that extends over nine orders of magnitude in x. Features of interest appear at 10^9, 10^13, and 10^16 in the scale. Using linear scales on the data waves, I loose resolution on features at the low end. I suspect that I have one of two options:
* Create an explicit x wave that is scaled logarithmically.
* Increase the number of data points in my scaled wave to recover the resolution at the lowest end.
Independently, I might wish for a new built-in feature to SetScale that would scale the x by logarithmic steps increments. Perhaps the x-scaling could even be designated by a function call (much as the TransformAxis package creates a new scaling axis).
SetScale/F=ScaleFunction x, ... Function ScaleFunction(p) : SetScale Function variable p return log(p) end
Is this idea worth any thought?
I'd support the request for log wave scaling. However, I'm aware that this will cause a lot of trouble 'below the surface'.
HJ
April 9, 2018 at 01:55 pm - Permalink
April 9, 2018 at 04:13 pm - Permalink
The graph shows eprd vs xe (and others). I generated xe as
xe = 10^(8 + p*(2e-4))
over 45001 points.The inherent ability to set the scale on waves by a function would be cool.
April 9, 2018 at 04:35 pm - Permalink
