Is there a way that I have missed to rename all waves in a graph semi-automatically by appending a suffix for example? Currently I am renaming them one by one manually but this is proving tiresome. So if I have wave1 vs wave2 plotted and would like to duplicate the graph with the exact data but the waves in the new graph are called wave1_dup vs wave2_dup as an example.
Yes. You need to write a procedure that grabs the list of waves in your graph and then renames them.
Function Appender(newsuffix)
String newsuffix
String wnames =wavelist("*",";","WIN:") //WIN: means top graph
String name, newname
Variable i
for(i =0;i < itemsinlist(wnames);i +=1)
name = stringfromlist(i,wnames)
newname = name + newsuffix
Rename $name $newname
Untested but should work. Call example would be
Appender("_dup")
Note 1 WIN: means top graph but you could edit this to specify which graph you want to work on.
Note 2 If you want to keep the current graph with wave1, wave2... and make a new graph with wave1_dup, wave2_dup... you need to edit the procedure to duplicate and replace (working on a duplicate of the original graph - cmd+d).
Untested but should work. Call example would be .
May 12, 2015 at 11:44 pm - Permalink
There is also a user interface for it: Right-Click on a trace and select "Replace Wave..."
- HJ
May 14, 2015 at 05:53 am - Permalink
