Reject small peaks in Multipeakfit
millot1
It seems that
Multipeakfit
is a much more powerful tool than the early findpeak
based routines...I was wondering whether there was a simple way to add a constraint to all peaks similar to the
/M
option for findpeak
?I would like to avoid including in the fit small "bumps" in the data
These adjustments are, by default, hidden in the Multipeak Fit panel. Below the Auto-locate Peaks Now button you will see a small disclosure control. Click that and you will see three new settings: Noise level, Smooth Factor, Min Fraction. Most likely you want to increase "Min Fraction".
April 15, 2015 at 09:27 am - Permalink
I had missed the little arrow to see the
setvariable
for those parameters...April 15, 2015 at 11:24 am - Permalink
