Proper titles for wave columns
My code does the job I want it to do, but it would help with the visualization of the data that it produces if I could modifiy the title of the wave columns. My complete code creates several waves in the root folder and then files these with data. The number of columns in each of these root waves is determined by the number of data folders (present in the root folder) which I want the code to work on.
I have a vastly simplified version of my code below. How would I modify the NiceColumnNames function so that instead of getting three columns all named 'PeakAmplitudes', I get three columns named: 'CG1', 'CG2' and 'CG3'?
Function MakeDFs()
NewDataFolder/O root:CG1
NewDataFolder/O root:CG2
NewDataFolder/O root:CG3
NewDataFolder/O root:Junk
Function NiceColumnNames (vTPWaveNrB4exp)
Variable vTPWaveNrB4exp
Variable vTotalNrOfDFs = CountObjectsDFR(root:, 4)
Variable vIndex
Variable vCounter
Variable vNrOfDFs
for (vIndex = 0; vIndex < vTotalNrOfDFs; vIndex += 1)
String sDFinRoot = GetIndexedObjNameDFR(root:, 4, vIndex)
Variable vMatch = StringMatch(sDFinRoot,"CG*")
if (vMatch == 1)
vNrOfDFs = vNrOfDFs + 1
Make/O/N=(vTPWaveNrB4exp*2+5, vNrOfDFs) PeakAmplitudes = NaN
For details execute:
Unfortunately, there is no way to show the horizontal dimension labels while hiding the horizontal dimension labels.
Another approach is to use table column titles. For example:
September 8, 2014 at 02:35 pm - Permalink
