Problem Transferring Structures between Procedures
jjweimer
// PROCEDURE FRAC #pragma rtGlobals=1 // Use modern global access method. Static Structure MyStruct variable tc endstructure Function ChangeStructure(ms) STRUCT MyStruct &ms ms.tc = 1 return 0 end
// PROCEDURE FRIC #pragma rtGlobals=1 // Use modern global access method. Static Structure MyStruct variable tc endstructure Function SendStructure() STRUCT MyStruct ms ms.tc = 0 ChangeStructure(ms) return 0 end
Trying to compile these gives an error message for Fric:SendStructure ... reference variable is of a different type. When SendStructure() and ChangeStructure(ms) are within the same procedure, I get no compile error.
What am I missing?
Igor 6.1.0.7 under Windows Vista.
June 26, 2009 at 09:45 am - Permalink
Oh! Duh! Not only that, but the Structure definition must not be static. The proper set up is ...
and
June 29, 2009 at 06:16 am - Permalink
