Problem with TN020 Procedures.ipf
wolf1988
i want to use the TN020 Procedures.ipf file, which i got here:
ftp://ftp.wavemetrics.net/IgorPro/Technical_Notes/
Problem is, i work in an environment in which the function calc already exists and i need to use both. I didnt program this environment/macros, so i want to avoid messing around with it.
When i open TN020 Procedures.ipf and then click on Macros -> initialize most everything i get an error:
"Name already exists as user function"
Error in TN020 Procedures.ipf:InitPeakMacros
String/G S_Wave,new,none,calc
So i just changed the name of the variable calc in the TN020 procedure to calcaz
Now a new error comes while executing Macros -> initialize most everything:
got "calcaz" instead of a string variable or string function name.
Prompt wx,p_wx,popup,calcaz+WaveList("*", ";","")
Even through calcaz is introduced in the beginning:
String/G S_Wave,new,none,calcaz new="_New_;" none="_None_;" calcaz="_calculated_;"
Has anybody an idea what s the problem?
Thanks in advance!
W.
1) Calling a function "calc" is not good practice. It's way too generic. Over the years my function names have gotten more and more bizarre; now I'm apt to use something like "IPF_calc_simulated_friction" where IPF might be an abbreviation derived from the package name. But you say it's not your code and you're stuck with it... The global variable in Tech Note 20 shouldn't use that name, either, but that code is more than 20 years old, and at the time it was written every byte had to be conserved so long variable names were not an option.
2) I tried the change you tried and it worked. Be sure you change every instance of the variable calc to calcaz. I must have changed about 20 instances.
October 31, 2014 at 10:23 am - Permalink
October 31, 2014 at 01:14 pm - Permalink
it works by now without problems.
Here is the modified version, if anybody wants.
November 12, 2014 at 05:34 am - Permalink
