Plotting a top axis
I have an x axis that converts in a non uniform way to a different value. I want to show both values on the plot, one on the top and one on the bottom. Right now I have 3 waves, the first one is the y value and the second one is the x value, and the third one is this non uniform transform to a second x value. So I want one plot and two x values showing on the bottom and top. Is there a good way to do this?
Michael
From Igor's Graph menu, choose Packages->Transform Axes
If one of the built-in axis transform functions is what you want, you're all set.
Otherwise, enter this command:
DisplayHelpTopic "Providing Your Own Transformation"
to receive instructions on how to create your own transformed axis function.
