Parse through textwave to look for specific character
Hello, I'm trying parse through a textwave that has data points containing things like "(4+)", "3+", "(17/2)-", "1(+)", "3/2-" , "(1,2)", etc. What I want to do is check if a data point contains a "+" or a "-" and if it does, put a "+" or a "-" respectively, into a new wave but in the same index as the wave being searched. I.e. if index (data point) 6 contains a "+", put a "+" in index 6 of the new wave.
I'm running into a problem where any data point that contains a "," , "/" , and "()" it doesn't work. Can someone help explain why StrSearch isnt working for this?
Function test()
    wave/T test_PI
    variable len = numpnts(test_PI)
    variable i
    make/O/T/N=(len) PI_tested
    For(i=0;i<len;i+=1)
       If(StrSearch(test_PI[i],"+",0)==1)
         PI_tested[i] = "+"
        EndIf
          If(StrSearch(test_PI[i],"-",0)==1)
            PI_tested[i] = "-"
          EndIf
    EndFor
StrSearch returns the byte offset of the character you are trying to match e.g. "(4+)" would give 2. If you don't care about the position of the character then maybe you need to use StringMatch, or GrepString, or just change ==1 to >-1 i.e.  (StrSearch(test_PI[i],"-",0) >-1)
Something such as this may be helpful.
Function check_signs()
    wave/T testwave
    wave iwave
    iwave = -GrepString(testwave[p],"-")
    iwave = iwave == 0 ? GrepString(testwave[p],"\+") : iwave
make/T/N=6 testwave={"(4+)", "3+", "(17/2)-", "1(+)", "3/2-" , "(1,2)"}
make/N=6 iwave
edit testwave, iwave
check_signs()
(edit -- now sets values for both negative and positive signs)
