Odd wave indexing behavior
jmbeebe
Here's some simple code that feels like it should work, but doesn't, and I'm wondering what's going on. I'm trying to populate a 2x6 matrix with two pre-existing 1x6 waves. I've tried this in multiple ways, and it never works the way I expect it to.
The following properly inserts wave0 into the first row of Matrix and wave1 into the second row.
Function ConcatenateWaves() Variable Number=CountObjects("",1) wave wave0 wave wave1 Wavestats/Q wave0 Variable Length=v_npnts Make/O/N=(Number,Length) Matrix Matrix[0]=wave0[q] Matrix[1]=wave1[q] End
If I try to automate that so I don't have to predefine wave0 and wave1 (there will ultimately be many more of these waves), strange things occur.
Function ConcatenateWaves() Variable Number=CountObjects("",1) Wave wave0 Wavestats/Q wave0 Variable Length=v_npnts Make/O/N=(Number,Length) Matrix Variable ni=0 String Name Do Name=GetIndexedObjName("",1,ni) Wave w=$Name Matrix[ni]=w[q] ni+=1 While(ni<Number) End
Here, I'm referencing wave0 and wave1 through GetIndexedObjName. When I do it this way, only the first column of Matrix populates - all other columns are zero. WaveRefIndexed behaves similarly. Clearly I'm missing something here, probably something obvious. What is it?
You need the empty brackets on the left side; then you can use q on the right.
But really, you want the Concatenate operation.
February 14, 2017 at 12:20 pm - Permalink
numpnts
.HJ
February 14, 2017 at 12:25 pm - Permalink
Second, your second function wouldn't even compile for me in Igor 7. You have to be a bit more explicit in your wave assignment; use Matrix[ni][]=w[q]:
Last, you might explore MatrixOp or Concatenate as alternative ways to do what you want.
February 14, 2017 at 12:27 pm - Permalink
Thanks John. That fixes it. I tried Concatenate and ended up w/ a 1x12 rather than a 2x6 - probably had syntax problems there as well.
February 14, 2017 at 12:46 pm - Permalink
Concatenate/O/NP=1 {wave0,wave1}, Matrix
forces appending columns, but without /NP flag it should just promote correctly if the waves are the same length.February 14, 2017 at 02:02 pm - Permalink
